4.10 Gears??
i run stock 4.10 on my 6spd x dana 35 and 44 with 35s and 33s (winter, summer) and i get threw all the gears just fine with my 33s i get a lot more spring out of the little v6 but its a jeep not a sports car.
you could allways test drive one with the set up or with the same ratio like stock 32s with 4.10 on stock rubi or an x with the street 29s and 3.88 would give you the same basic power points.
just my 2 cents but you wont know till you try it and the cheaper the better
My 4.88 Gear Review
My '08 2 dr X 6-speed has the 3.21 gears, a D30 up front and a D44 in the back. I'm running 33" BFG M/T's and don't plan on going bigger. My lift is the RE 2.0 coil spacer with RE monotube shocks and JKS discos. I run mainly 2.0~3.5 rated trails.
I have two questions....
- what do you think about running 4.10 gears with my set up?
- do you think I need to add anything to beef up my axles or lift if I install the 4.10 gears?
Thanks for your inputs....
I just think, that if you are going to re gear to 4.10's, you mind as well get the 4.88's
Then again... my still not entirely convinced I have 4.10 gears even after verifying with my dealer. After testing and using the above charts as a reference, my numbers are not even close to matching what's on the chart. In fifth gear at 70mph, my tach shows 3100 rpm which would lead me to believe than I'm closer to a 5.13 gearing...
if your tires will not change from 33"... 4.56 would be the gears for me. borderline freeway acceptable at 2700rpms at 70mph in 6th..
And, as noted above, the chart specifies 6th gear, not 5th...
you said you dont plan to go any bigger than 33" tires didnt you? I think 4.88 is too much gear for you with a 6th speed. Most people overdo it just to be safe and then suffer on the freeway. How much freeway do you do? You currently have 3.21's and with each gear step your rpms will go up approx 300rpms. So drive the freeway at 70mph in 6th gear right now with 3.21s. If your speedo works you will be at about 1900rpms.. I know because thats my setup, except for 32" tires (im at 1950rpms). Then think about going from 3.21 to 4.88. Thats 4 steps, or around 1200rpms higher. See if you could stand 1200rpms higher constantly on the freeway.
I would suggest most people look at under gearing as the appropriate gear sets are much higher than what is viewed to be the norm. From the gut, when I think of 4.56s that's a pretty steep gear set but when I use my head and knowing what the JK delivers, it's way better to twist it approaching 3k than it is to have it coughing under 2300rpm.
