4.27 Gears for the D30 and D44?
Old May 21, 2009 | 09:42 AM
RedneckJeep's Avatar
Originally Posted by Torrin
4.56's are good for a manual with 33's maybe going to 35's. 4.88's are not much different in ratio and 4.56's will not over rev 33's to much.
Thanks for makin my point. 4.88 is a tad more gear. It's always good to have a little more than you need than a little less. I never saw the need for a .56 gear. It just doesn't make sense.
Old May 21, 2009 | 09:43 AM
seer1's Avatar
Originally Posted by nthinuf
And do you have any intention of going to a 35" ?
My suggestion:
Manual with 33's - 4.10 or 4.56 for towing
Auto with 33's - 4.56 or 4.88 for towing
If you have even considered the possibility of 35's, bump those up a gear size.
Here we go again. Anything under 5.13's is a waste of money for autos.
Old May 21, 2009 | 10:50 AM
nthinuf's Avatar
OD on and not towing, no question I'd agree.
33's, towing with OD off, cruising at 70-75 on the freeway? What rpm range are you in?
Unless you'd recommend I tow my 3500 lbs boat in Overdrive?? No thank you...
Old May 21, 2009 | 10:57 AM
seer1's Avatar
Why the hell do you want to turn your OD off?
Old May 21, 2009 | 11:08 AM
nthinuf's Avatar
Everything I've ever heard or seen is 'push the tow/haul button', or 'OD off' when towing. If my JK had the engine and drivetrain out of a 1 ton truck, sure. But it doesn't, so I'd rather not take the chance of helping my transmission to an untimely end...
Old May 21, 2009 | 11:45 AM
It's an automatic transmission. It knows what to do.
Old May 21, 2009 | 11:50 AM
So manual and 35's one day soon 38's 4.88 or 5:13's???
Old May 21, 2009 | 12:24 PM
nthinuf's Avatar
From Jeeps website...
When You Have An Automatic Transmission With Overdrive
* In hilly areas and with heavy loads, it is recommended you lock the transmission "out" of overdrive to prevent excessive gear shifting
May just be me, but I would consider a 3500 lbs boat to be a heavy load for a JK.
Apparently it doesn't...
Old May 21, 2009 | 12:47 PM
...and WHERE again in this thread were we talkin about towing?
Old May 21, 2009 | 01:33 PM
nthinuf's Avatar
In the OP's original post, perhaps ?
Or with your vast experience did you not even bother to read it? I already said I agreed with you on the 5.13's. But I also feel that going too deep is a consideration if you'll be towing, and it's worth mentioning, instead of just laying out a blanket statement that anything under a 5.13 is crap...
