4.88 or 5.13 which one
Was planning to run 35s too. I guess the general view is 5.38s or at least 5.13s with a 4dr auto rubicon. I hate that too because I set up my YJ with 5.38s and it bothers me how incredibly small the pinion gear is with that "high" of a ratio. I actually have to replace the rear gears every so often because the pinion teeth develope stress cracks when hammered on repetitively. 5.38s have 43 ring gear teeth and the pinion only has 8 teeth. As compared to 41 and 11 for the 4.10. I guess it's a mute point since the 4.88, 5.13, and 5.38s all have an eight tooth pinion. I guess I'm secretly trying to talk myself into a D60R.
This is a great point, as the gear ratio increases, the teeth on the ring get smaller. I probably would stick with 5.13, and only to 5.38 on a dana 60.
The ring gear I don't worry too much about. Like was said, the difference is nominal. But when you only have EIGHT teeth on the pinion, one more tooth makes a big difference in how many teeth are actually in contact with each other.
I agree and would bring it a step further and tell you that once you go past 4.88 on a D44 the gears are the weak point. (I would go with 4.88) 5.38 is definatly only for and should be in a D60
