4"long arm kit with 37or 35?
even with 35 I would suggest to replace axles with cromoly ones, put inner sleeves and C gussets. a Rubicon axle is not stronger than any other stock JK axle and they are weak for tires above 35''
somes will say that stock axles are fine with 35 or 37 but the driver and purpose might be a limiting factor.
The weakness of a stock JK axle is not the ring and pinion size or the spline count...
Well this is where we will differ and I'm sure a lot of others will too. The Dana 44 Rubi internals are way stronger than the 30's or there would be zero market for the pro rock 44, tera 44 or core 44. Everyone would just sleeve /truss and gusset the 30 and call it done. As I said both suffer the weakness of thin walls and to tall and thin c's but that is where it stops
