4" Superlift questions
#21
JK-Forum Founder
As you all can tell... I am completely torn between the lift that I want. I figure that I am probably not going to run 37's and just go with 35's, since I have had great experiences with 35's (I guess bigger is always not better ). I may just stick with my original plan and go with the 4" Superlift and possibly upgrade it later as stated above. Seeing since I am not willing to spend $1000 more on the 4" Teraflex I started looking at their 3" kit, but I think I would be more happy going with the 4" Superlift in the end. Has anyone rode in a JK with a Superlift and one with a Teraflex lift, I am wondering about the ride quality since I will be driving my JK approx 30 miles a day. Thanks for the opinions!! I greatly appreciate them!
#23
Also consider that Superlift does or will soon offer their rock runner control arms that you can upgrade to with their 4" lift in the future. I say get the Superlift 4" with the adjustable front and rear track bars, and upgrade to their rock runner arms later....
Oh... and GEAUX TIGERS!!
#24
#25
Don't let anyone dissuade you from your decision. Superlift makes a good product. You can upgrade the lift as your budget dictates. Basic kit now, arms later, better shocks later, whatever you decide. For that matter most of the lift manufacturers kits are modular. You can start inexpensive and go from there. When your looking for information on making your decision, use all of the webs resources. There are a lot of freindly people who will help. Talk to folks who have the lift installed that you are considering. Good luck.
#26
JK-Forum Founder
#27
Are the "alignment cams" that Superlift includes with the basic kit for caster angle realignment not sufficient to correct caster with this lift? I realize they go about it different than adjustable arms, but they do advertise them as being able to adjust and correct caster, was wondering what your experience was.
#28
Only because that is what you were initially interested in. Full Traction doesn't make a 4" lift, so I didn't suggest you get it.
35's look and work great with a 3" lift, but you'll need a 4" lift for 37's should you choose to get those. I suggest figuring our your tire size first and then selecting the lift you want. From all I have learned on this forum, I would pick a lift that you can afford with the option of upgrading later. For me, it will be the FT Ultimate control arms at some point.... Good luck!
#29
JK-Forum Founder
#30
Exactly - every lift kit can be built up upon as budget allows. While I have no doubts that the 4" Superlift kit is a quality product, it is essentially just a set of springs, rear track bar relocation bracket and front adjustable track bar. The only thing I have been trying to encourage you to do is to consider getting, at the very least, a set of adjustable upper and lower front control arms sooner than later. And, I only recommend this as at 4" of lift, your Jeep will have wandering issues at highway speeds if you don't set your caster to compensate for the amount of lift/bigger tires you will have.
