40" Tires
Old Jul 25, 2010 | 02:56 PM
08RedRecon's Avatar
Originally Posted by planman
I run 40s on my 2dr 6 speed Rubi.
I did it with:
  • flat flares
  • 1" body lift
  • 3.25" front and rear extended bumpstops (on 3" OME HD springs with 0.5' coil spacers)
  • 3" net wheel backspacing
  • move rear axle back 0.75" which required relocating the frameside axle bracket back, coil spring retainers, custom bent rear swaybar links to clear axle brackets, and rear lower coil wedges
  • generous trimming of the rear fender well
  • trimming of the front upper edge of the front fender well
  • I may eventually trim the back lower edge of the front fender well
  • PSC hydro assist steering
  • Dynatrac ProSteer ball joints
  • chromoly front and rear axle shafts
  • 5.13 gears (remember that I have a 6 speed)
  • front axle sleeves, gussets, and truss
  • custom rear bumper
  • longer bolts from the hardware store to replace the stock steering stops
  • Tom Woods 1310 rear driveshaft
  • chromoly tie rod
  • adjustable front lower, rear lower, and rear upper control arms
That sounds like a beast.
Old Jul 25, 2010 | 02:59 PM
Brashanic's Avatar
i just measured my spare tire carrier. i don't think a 40 will fit. it's a Hanson the only clearance issue seems to be the bumper. i think i can fab an offset though.
Old Jul 25, 2010 | 03:06 PM
Steel Rain's Avatar
Originally Posted by Brashanic
nice post. thank you. i already have Tf 4" lift maybe i will have to add a 1" bodylift.
did you move the rear end back for tire clearance or to extend the wheel base?
my front end is already bent so i am going to put in a PR44 and RCV.
i just put hardened shafts in the rear end.
see this is what i mean. i am almost there with what i am already doing for the 37's.
I Brainfuck myself over this crap too much.
"I Brainfuck myself over this crap too much". You aint the only one brotha
Planman: As always you are one of the GURU'S
Old Jul 25, 2010 | 03:23 PM
Brashanic's Avatar
Planman rear wheel position looks great. the whole thing looks really good. i probably have 6 months to think about this.
i think i will put my gears in and see what i think of my throttle response on a day to day basis. i drive this almost everyday. (but i don't have to)
Old Jul 25, 2010 | 03:26 PM
Brashanic's Avatar
btw: how was hells gate? no drama?
Old Jul 25, 2010 | 03:41 PM
Brashanic's Avatar
very nice. i want to run that really bad. but the all the videos of people messin up kind of got under my skin.
really cool you guys running that together.
Old Jul 25, 2010 | 05:36 PM
johnnyj33p's Avatar
Looks great! Good job! I think its awesome you set your son up too! What a great way to hang out together!
Old Dec 5, 2010 | 09:08 AM
mr_natural78's Avatar
Ha. I'm in the same boat. I am about to replace my D30 for a D44 with Chromo shafts and CTM u-joints. Also re-gearing. I was planning on going up to 37's for my text tires. Now I'm looking into gussets, outter sleeves, a truss, and thinking screw it...maybe I should go to 40's.
Old Dec 5, 2010 | 09:44 AM
rage.690's Avatar
Don't need 40's for the rubicon on a four door. Did it a couple months ago on stock rubi 32's with a four door 3.5 inch lift. Need a good spotter and armor up! I plated the crossmember with 1/4 steel and covered the crossover. Plated gas tank with 1/8 inch after the trip. Destroyed stock crossmember on trip. Small tires make for a challenge. Winched one time.
