4wd linkage cable adjustable
Old Dec 16, 2014 | 12:13 PM
GulfCoastJeeper's Avatar
Default 4wd linkage cable adjustable
I replaced my transmission and since putting it back in my jeep will not shift into 4lo and slides out of 4 hi into 2wd with ease. Is the cable adjustable?
Old Dec 16, 2014 | 02:27 PM
Invest2m4's Avatar
Same transmission? Double check the shift cable and linkage for the transfer case. Replacing the trans shouldn't make a difference If it was the same one. I and many others swap t-cases without issue.
Old Dec 16, 2014 | 02:31 PM
Different tranny. But it's out of a JKU of compatible years
Old Dec 16, 2014 | 04:44 PM
Invest2m4's Avatar
I meant same model trans? Sounds like it. Then you need to check the t case linkage and see if it's routed right.
Old Dec 17, 2014 | 09:01 PM
Ok. I'll take a look. I thought once it was clipped into the bracket it wouldn't matter how the rest hangs.
