5.13 or 5.38?
I'm currently running 35" tires on an 2011 automatic. I'm going to regear in the near future.
I know the recommended ratio is 5.13, but checking the charts 5.38 is in the optimal range for 35" and 37".
What would going with 5.38 do compaired to 5.13? If I plan on putting 37's on in the future, would it be ok to go with 5.38 now so I won't have to regear later?
or is this a bad idea...
If you have a rubicon then 5.38 is an option for you and cause you have an auto i would reccomend it. If you dont have a rubi then , despite the fact that some company makes 5.38 for the d30, i would stick with 5.13s.
Is the cost similar regardless of which one I go with? I was quoted off the cuff in the ballpark of $1k per axle. Not sure if it varies much. I have Rubi so was looking at 5.38.
