5.13 gears
Old Dec 27, 2011 | 05:18 AM
  #51
JPop's Avatar
Originally Posted by EarlyJk
I am in awe of the detailed responses you always give. I like to constructively argue back an forth on issues but your responses have no holes! Lol. If i ever get stuck on an issue, I hope you dont mind but Im seeking you out.
Cheers!
Thanks for the kudos, but remember that I like everyone else is not omnipotent. I make mistakes just like everyone else and sometimes what I believe from the seat of my pants, remember from a lecture of thirty years ago, or the data I collect from a spreadsheet just simply isn't correct or based on a false premise. I learn a ton here just like everyone else, although my years probably grant me more wisdom from the school of hard knocks.
I certainly don't mind seeking me out for help, just keep in mind you should weigh my answers with your own experiences and the advice of others. I'm pretty sure that's why we're all here.
Old Dec 27, 2011 | 05:27 AM
  #52
Danny4652's Avatar
Originally Posted by Jreyes24
What kind of programmer do u have?
Superchips Flashpaq
Old Dec 27, 2011 | 06:10 AM
  #53
JPop's Avatar
Originally Posted by Dronac
My parents had a Town and Country with the same engine our JK's have. When I was considering a regear, I did some observations on it's highway performance. It seems that it ran similar RPM's as our JK's do at the same speeds. That is to say that at 70, both would turn around 2000 RPM's. However, the Town and Country almost never had to downshift. It cruised right along at 2000 RPM's on the highway without an issue. Perhaps the gearing in the JK's is appropriate for the engine, but not the aerodynamics. On paper, it should have been perfect, but in application, especially after a lift and new tires, it was downright aweful.
IIRC, the new 2012 auto's are geared lower in the transmission, and have a higher output engine. If nothing was wrong before, why lower the ratio after adding the Pentastar? My parents just got a new Pentastar powered Caravan (equivelent to the Town and Country) and it's RPM levels are the same as with their old T&C. I think this showes that Jeep did see an issue with the old 07-11 JK driveline configuration, and took steps to correct it.
You can pretty easily look at the bin parts available and determine that Chrysler didn't have a lot of options. The Pentastar platform was under development and their 4 cylinder program needed more than a prayer. The options were going to an 8 cylinder 4.7 which blows out the cost structure, or doing what they did. Not that it was derived at by some sort of engineering prowess, but it's what was available in the cupboard. Then of course the vehicle was long on the drawing board before the first one was ever built, and of course so was the Pentastar.
Not sure by any means, but quite possibly the Pentastar was scheduled to be released at the introduction of the new JK. Enter Daimler to get in the way and trying to sell off this albatross and leveraging the brand to create new sales. What I see in the 2012 JK is everything I had hoped my 2007 would be. Perhaps, just perhaps that is exactly what the engineers had hoped it would be as well.
Old Dec 27, 2011 | 07:19 AM
  #54
OutlawJoker's Avatar
Well planman, I have a '11 sport S 4 door JK and driving around the Fort Worth area feels like my jeep is lacking power/balls. I can't imagine not regearing all Jeeps. I have been putting my build list together and one of the 1st things i have on my list is new gears. So far that is the only complaint i have had with my JK. I'll let you know how it feels when i get my regear done.
Old Dec 27, 2011 | 07:40 AM
  #55
jimk403's Avatar
All I can say is; Wow.
I guess if you live in Texas, the JK is geared perfectly from the factory. For the rest of us, re-gear, you won't be sorry. Heck, I re-geared to 5.38 with stock tires, a little low, but I liked it.
Oh, and if you can't post from your Iphone, get an Android.
Old Dec 27, 2011 | 08:33 AM
  #56
FrostByte's Avatar
Has anyone every seen anyone who regeared with 35s or larger say they wish they had never regeared? I've only seen people say they wonder why they waited so long.
Old Dec 27, 2011 | 09:34 AM
  #57
sringer's Avatar
Originally Posted by planman
The only regrets I have read from automatic owners are from people who didn't gear low enough (I.e. 4.88s instead of 5.13s, or 5.13s instead of 5.38s), with CJ7nvrstk as the only exception. Although, he did not try 5.38s with his 37s for a basis of comparison.
I have occasionally read posts of people who did 5.13s with a 6 speed and 35s who daily commute at speeds over 75 mph who felt they went too low. They typically just drive a little slower or upgrade to 37s.
That says it pretty good right there. I'm in a 2dr auto and still went with 5.13 for my 35x12.5x17 km2. I'm going to 37's soon and this will help push em
I am here: http://maps.google.com/maps?ll=48.431230,-114.341961
Sent from my iPhone 4s using Verizon 3G
Old Dec 27, 2011 | 09:47 AM
  #58
gilb001's Avatar
If you have an automatic transmission that hunts between the overdrive and 3rd gear at highway speeds with your stock gears now, you will notice an improvement in fuel economy with 5.13s.
This is plain logic because when an automatic transmission downshifts at close to wide-open-throttle with frequency, the fuel economy is much worse than running slightly higher rpms in the overdrive gear with minimal downshifting.
That being said, 5.13s in an automatic 07-11 JK are completely worth it for 33"-35" tires just for the improved performance alone--irrespective of the improved mpg.
would it also be good in a 6 speed?
Old Dec 27, 2011 | 09:55 AM
  #59
This may seems like a stupid question but i was wondering what the difference was between the 4.88 reverse and the regular 4.88's? I am certain i will need to regear and since i know exactly sqwat about gearing i don't know what to order. When i look them up they always ask for reg. or reverse. Will i need to by gears for both?
Please help the blind....
Thank you.
Old Dec 27, 2011 | 11:00 AM
  #60
Cdyspeed's Avatar
The 6 speed is different because the transmission gearing is different. So, 5.13s with 35s is too low if you commute at 75 mph+ on a daily basis.
To start off with I have a 11 2dr 6speed
Not trying to start another argument or anything but Like i have been telling people and everyone here probably already knows where i stand on this whole situation 4.88s with 35's is way to much still traveling at 75+mph. if you have a manual and do a lot of highway and don't ever plan on going to 37's go with 4.56s. I can run 37s on my 4.88s with no problems even going up the big mountain we have here in the middle of the town. i get my best mpg going about 60-62mph if i go any higher it drops tremendously. This is my opinion just as everyone else has theirs im just trying to give you my situation so you or anyone can learn from it. i will add the 4.88s are great power around town but highway it makes me regret ever getting them.
