5.13 gears....
I know people are sick of this question.. this may have been answered before...sorry. But the search function is crap on this forum. but here it goes. I have an 09 Sahara unlimited. I know I want 5.13 gears (plan on putting 33's). And I have found a place that strictly builds up jeeps. mainly JK's. they even do hemi swaps. but. I was quoted over 2K for 5.13 gears installed I don't know much about this but I know when I'm trying to get screwed over.. Maybe because I'm only 22 but any way.. Exactly what parts would I need for the swap.. I'm pretty sure 5.13's would fit my dana 30?.. also What is a good brand/most expensive ... I figure I won't go cheap on the gears... Thank you for your time!
Over two grand is too much. I live in NY/NJ area where everything usually costs more and Im paying around 1700. And thats with overhaul kits and about 11 hours labor. I think average is about 1200 to 1800 and 1800 is pushing it.
I recently had 4.88's installed, in place of 3.73's. After parts, labor and taxes, the total was $1452.00. This was in a small shop and the owner said he did 100 gear changes last year. Avg seems to be $1500-1600.
im running 5:13's with 33's and i can tell you it is WAAAYYYY overkill. but i also have the 6 speed. if all your going to run is 33's then look at 4:56 or 4:88 tops. Just my 2 cents though. I will be goin with 38's very soon and thats the only reason i went 5:13 and yes 2k is to much for gears. try a different shop
The 6 speed has a 0.84:1 overdrive and the auto has a 0.69:1 overdrive. The 6 speed has a 4.46:1 first gear ratio and the auto has a 2.840:1 first gear ratio.
So it's an apples to oranges comparisons. Auto guys should not be giving 6 speed guys advice based on their experience or vice versa.
So with 5.13s and 33s and a 6 speed he'd turning about 3,300 RPM at 75 MPH. That and 1st gear would probably be completely useless on the street.
But If he has an auto he'd be turning 2,700 at 75 MPH and it would probably be a pretty good setup.
The Dana 30 is too small for 5.13 if you wheel it real hard you will be replacing gears. The ring gear teeth become you weak point so you won't break axle's you will go through ring and pinions.You would be fine with 4.10 and 33" I would not go much high maybe 4.56 but that is it. Just the 2cents of someone who went through 2 sets of gears in my dana 30.
It all depends if he has an auto and 6 speed. Everyone here is probably sick of hearing my ranting because I get cheesed off when I hear auto guys telling 6 speed guys which gears to use and vice versa.
i just put 5.13's on in the garage with about $350 dollars worth of tools (instead of the 800 labor charge) and i am running 37's, well 36 1/4 to be precise in my manual, daily driver. highway speeds in 6th gear are at the 3K rpms, I can only imagine how high it would be running 33's. My jeep came stock with the 3.20something ratio and the almost 32" bridgestones and 6th gear at 70 was low rpm's too low for hills or to feel any torque. I haven't got to do any wheeling or 4 low driving but I think I would have been just as happy with the 4.88's as a dual purpose rig. If you are running 33"s and it is dual purpose, consider choosing a different ratio other than 5.13, but if it is strictly trail, then it will be a torque monster.
and exhaust tip is bent.
