5 of back spacing??
How wide of tire are you putting on? Most people run around 4.5". Are you concerned about how far the tire will stick out? If so you should consider measuring offset instead. I think the stock tires have a 44.45mm offset.
The rims I am getting have a 10mm offset so 44.45 - 10mm = 34.45 mm which is 1.3" farther out.
But it will still be determined on how wide the tire is.
Here is the link to a good thread.
https://www.jk-forum.com/forums/show...274#post211274
Offset and Backspacing is one in the same. Offset just refers to the centerline, and backspacing is the measurement in inches from the back of the rim to the lug holes.
Am i gonna stick out too much and do you think ill have rubbing issues at full turn. Im a newbe at all this and i went whit what the guy at the shop told me...the bigger the better...guess thats not true..
so if your new rim has an offset of 10mm then 44.45-10mm = 33.45mm/ 25.4 = 1.35"
+ .5" (for a 1" wider tire) = 1.85" farther out.
Backspacing does not mean anything without knowing the wheel width.
The formula for backspacing is: nominal width plus 1", divided by 2 (to get centerline), then add the offset (positive or negative).
4.75" backspacing on an 7.5" wheel will locate the tire under the JK at the same location of an 9" wheel with 5.5" backspacing.
