Which 50" lightbar mount??
Old Aug 21, 2014 | 07:28 AM
ski-YA-later's Avatar
Default Which 50" lightbar mount??
Could not find a thread on this...
Finally bought a 50"
Which is the best valued light bar?
Looking for
  • low profile
  • ease of hiding wire
  • possibility of lower tabs
  • Some sort of insulation on inside to protect body
Not going to fork over $260 for the poison spyder one, which I think is the best looking- but not justifiable for me.
The crawler concepts mount seems to be pretty sweet, but I want to see some more pictures of it.
Or just get an $80 mount and live with it being a little higher and sticker further out than I would like.
Thoughts? What are your experiences?
Cheers!
Old Aug 21, 2014 | 08:00 AM
TheNoob's Avatar
If I had to do it over again I'd go with the Crawler Concepts bracket. Looks great, reasonably priced and seems to have tabs for the lower a-pillar lights. . I went with Rough Country brackets as well as some eBay brackets for the lower a-pillar lights. Only cons of my set-up are that I had to source longer bolts to run both brackets (no biggie though) and it's a PITA trying to install them by yourself, you need someone to help you hold the brackets to line up all the holes correctly. Other than that I think my set up looks great. The Poison Spiders are way too expensive imo.
Old Aug 24, 2014 | 05:30 PM
Thanks noob.
Anyone else? I want to see some more pictures of the crawler concepts one, I reached out in there thread and did not get a response.
Old Aug 24, 2014 | 06:29 PM
nh08jk's Avatar
I got the crawler concepts led lightbar but I have not put it on yet as I'm stilling looking for a good led light bar. I think I'm going with the dv8 light bar. Here are some pics of me priming it and bed lining it as well
ID:	572832   Click image for larger version
ID:	572833   Click image for larger version
ID:	572834   Click image for larger version
ID:	572835   Click image for larger version
ID:	572837   Click image for larger version
ID:	572838   Click image for larger version
ID:	572839   Click image for larger version
ID:	572840   Click image for larger version
ID:	572842   Click image for larger version
ID:	572843   Click image for larger version
Old Aug 24, 2014 | 07:33 PM
Nice! Looks good. I will probably pull the trigger on it. The light bar I got is a 50inch from the online auction site- 150 bucks! I will post up how it turns out.
Old Aug 24, 2014 | 08:16 PM
So-Cal4x4's Avatar
Former Vendor
This is the bar we run... with the LifetimeLED 50"
Combo 50" bracket for Jeep JK (2007-present) and 50" 100 LED bar
Old Aug 24, 2014 | 08:26 PM
jeeper1988's Avatar
Whatever you do make sure you get it locked down as safe as possible. My rigid sr was stolen last week!
Old Aug 24, 2014 | 09:44 PM
sea bass's Avatar
Originally Posted by So-Cal4x4
This is the bar we run... with the LifetimeLED 50" Combo 50" bracket for Jeep JK (2007-present) and 50" 100 LED bar
Hmm...this mount looks a little different. Puts the light a little higher than most. Do you get less turbulence with this? Less flutter with a soft top?
Old Aug 25, 2014 | 03:02 AM
2k12jk's Avatar
Rick Slide Engineering made mine, solid one piece aluminum, no ugly joints or welds.
Old Aug 25, 2014 | 09:07 AM
Thanks for all the reply's ^That Rockslide one looks good!
Anyone use the Hyline mount? HyLine OffRoad 400600100 - HyLine OffRoad LED Light Bar Mount for 07-15 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
I like they say you can run the wire underneath it, but no lower mount tabs.
^Bummer your light was stolen! That is partly why I got the $150 50".
