5x5" bolt pattern to 5x5.5"?
Hi everyone,
I love the American Racing Mojave in Black, but it doesn't come in a 5x5" bolt pattern. Go figure.
Anyway, aside from trying to persuade American Racing to offer it in 5x5" (which I'm also trying to do), I was wondering if I could change my axles' bolt pattern from 5x5" to something more widely available, like 5x5.5"? I was planning on selling my original wheels anyway... :-)
Here's a link to the Mojave:
http://www.americanracing.com/wheels...sh§ion=ORT
Feel free to send 'em an e-mail asking for a 5x5"....
Thanks,
js.
Anyway, aside from trying to persuade American Racing to offer it in 5x5" (which I'm also trying to do), I was wondering if I could change my axles' bolt pattern from 5x5" to something more widely available, like 5x5.5"? I was planning on selling my original wheels anyway... :-)Here's a link to the Mojave:
Thanks,
js.
You could always install a set of wheel adapters like these to change your bolt pattern:
http://www.northridge4x4.com/proddet...SPIDER-WHS-012
Only thing is, they will reduce your backspacing by 1.375" but then, you may need it depending on how wide a tire you're planning to run
Thanks!
js.
Well, once they are available, you could always upgrade your axle shafts to a set of chromoly ones and they typically come in comon bolt patters or in dual bolt patterns to accomodate both
Guys, while we're on the subject,
Are the wheel adapters safe, ie. is this the whole Spidertrax issue all over again?
And, one other thing: what do HUBCENTRIC rims mean? How would tell one apart from a non hubcentric one?
THANKS in advance
THANKS in advance
Hey Eddie,
Almost ALL factory wheels are hub-centric despite that they also use the tapered nuts that you describe. In my opinion, hub-centric rims should be used whenever possible. Hub-centric wheels are much better and safer wheels. Shear forces are not on the lugs themselves, but carried by the hub portion of the wheel. The reason that many aftermarket rims are not hub-centric is that they are designed to fit a wide variety of applications. So, it is an expense issue for the manufacturers.
That's what I thought was going on with the hub-centric stuff. Given my hit probability lately, though, I chose to keep my mouth shut. Thanks for clearing it up, WOL.
Alloy shafts sound like a nice thing for you, Morris, like WOL was talking about. Would be hard to justify the price tag, though, just for a different bolt pattern. Unless you've got the coin, of course. If you're planning on bouncing around on a tough trail, or running large tires though..........
Plus, they come with stickers.
