6.4L Hemi $3500 ????
Old Feb 17, 2013 | 08:25 AM
burton50x's Avatar
Default 6.4L Hemi $3500 ????
Just though i would share...seems very low to me.
h t t p://denver.craigslist.org/pts/3615887635.html]2012 392 6.4L HEMI ENGINE
Last edited by scooby snacks; Feb 17, 2013 at 11:06 AM. Reason: Non-sponsor link; put in url without actual linking
Old Feb 17, 2013 | 09:12 AM
dwhitt74's Avatar
Former Member
"It had a bent rod but did not damage the crank or cylinder walls. you could reassemble with one new rod and piston with rings then change the oil filter housing/cooler and oil pump"
-straight from the ad...
Old Feb 17, 2013 | 10:41 AM
burton50x's Avatar
ya roger read that but after buying those parts its still only like 4000 grand for a 6.4L complete
Old Feb 17, 2013 | 10:55 AM
dwhitt74's Avatar
Former Member
I'm not an engine expert, but if I were going to check this out I would want to have one with me. Just because he said those are the only things wrong with it, doesnt mean it's true. Bent rod is not good. now, if you know your way around an engine's insides, I think it is probably worth checking out. Engines can get expensive fast, though if there are unforeseen issues. Post up if you get it!
