6 inch short arm
Old Aug 22, 2011 | 07:01 AM
snopro269's Avatar
Default 6 inch short arm
Is anyone running a 6 inch shortarm on a 2dr?
Old Aug 22, 2011 | 08:19 AM
Full-Traction Suspension's Avatar
Former Member
I doubt you will find one.
We do not even sell a 6" kit for the 2 door short or long arm. It too high and it's causes issues with the driveline angles.
Old Aug 22, 2011 | 08:36 AM
GatorLCA's Avatar
You're better off doing a 4" suspension lift with a 2" body lift.
Old Aug 22, 2011 | 09:16 AM
snopro269's Avatar
Well I see that TeraFlex sells a 4 inch for a 4dr and it's claimed near 6inch on a two dr
I an running a lot of weight so I was considering this route
Old Aug 22, 2011 | 10:16 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Your going to want long arms if your going that high in a 2dr. 6" coils plus short arms on a 2dr would not be a fun ride.
Old Aug 22, 2011 | 12:18 PM
snopro269's Avatar
So Maybe just put in 4 inch springs instead?!
My 2.5 unlimited coil lift constantly bottoms with less than 4000 Hwy miles on the lift!!
That's why I'm thinking going bigger springs!!
Old Aug 22, 2011 | 12:19 PM
snopro269's Avatar
I have complete upper and lower control arms minus front uppers that I recently purchased?!
So should I have gotten longarm instead?
Old Aug 22, 2011 | 12:31 PM
TeraFlex's Avatar
How big of tires are you running?
Old Aug 22, 2011 | 12:38 PM
KenB1010's Avatar
If your reason for going to 6" springs is weight. You might want to go with 4" springs for a 4 dr. That will get you a higher spring rate to help with the weight. That's the route I'm taking due to the added weight of my Aux fuel tank.
Old Aug 22, 2011 | 12:39 PM
snopro269's Avatar
35's moving to 37's
No rubbing issues just bottoming
