6 inch short arm
Old Aug 22, 2011 | 04:12 PM
  #21
snopro269's Avatar
Originally Posted by TheDirtman
The ome hd are rated for a constant 300 lb load and the +40's handle even more weight. I looked at your profile and it doesn't look like you are carrying that much weight unless you are really heavy.
I dont list all my stuff on here but let's see
Yeah it's a 2.5 coil lift with control arms but no drive shafts. A little recovering gear but not fully loaded. No handyman or chains. For armor I have front Shrockworks electo disco skidplate, evap skid, front rear diff covers, heavy-duty oil pan, Shrockworks rockrails and front bumper. A rear expedition one bumper with factory rubicon rims and 35 MTR's
And on the Scales it was 5000lbs with full tank of gas, minus 250lbs of me
Old Aug 22, 2011 | 05:02 PM
  #22
knnphillips's Avatar
Are you planning to stick with 35s possibly go 37s further down the road? If that's all your intentions are I wouldn't recommend anything over 4 inch heck even with trimmed fenders you nay be able to fit bigger under there with 4 inches. The major thing is the springs will not sag with the weight and that is what your trying to compensate for by going to a larger lift.
Old Aug 22, 2011 | 07:05 PM
  #23
snopro269's Avatar
37's are max size !!
I already have cutout flatties
I'm trying to quit bottoming out just over curbs and basic stuff yet alone offroading
Old Aug 23, 2011 | 03:42 AM
  #24
I'd just get a set of the OME HD coils or OME +40 coils and maybe a set of Teraflex or King speedbumps if the heavier duty coils don't solve your problem.
Old Aug 23, 2011 | 04:37 AM
  #25
snopro269's Avatar
I will have to looking into OME
I really like TF so far so hoping they have something that would work
Old Aug 23, 2011 | 07:06 AM
  #26
TeraFlex's Avatar
Sponsoring Manufacturer
Getting a set of SpeedBumps installed is a good way to prevent harsh bottoming out. Or if you don't mind a little firmer ride, a set of Fox shocks.
Old Aug 23, 2011 | 07:32 AM
  #27
snopro269's Avatar
I thought the Fox shocks were valved specifically for the prerunner setup
Old Aug 23, 2011 | 07:53 AM
  #28
TeraFlex's Avatar
They can be used with any JK suspension, they are just valved firmer than a normal shock/ELKA. ELKA's compress well vs. Fox's extend well. So if you want to counter your JK bottoming out, you will want a shock that extends well. You can even use the lower priced 2.5" rear SpeedBumps to help out, $82.99.
Old Aug 23, 2011 | 08:29 AM
  #29
But would the 2.5 speedbumps be adequate to keep from rubbing if he decided to switch to 37s?
Old Aug 23, 2011 | 08:34 AM
  #30
TeraFlex's Avatar
These are placed in the rear upper bumpstop location, they are 5" long. You can use these along with the standard rear lower bumpstop block from TeraFlex. Or just install the #1958602 $495.99 normal rear SpeedBumps which are 6-3/16" tall.
