About programmers
Old Jun 30, 2008 | 09:54 AM
Bodo's Avatar
Default About programmers
What are the benefits to programmers such as the Hypertech other than calibrating the speedometer, gear ratio, gas octane? If I go to 35's , reset the speedometer for the tire change, or don't, will there be any other problems. Such as BAS/ESP issues?
Also, what other brands are available?
The Hypertech is around 400.00??
That seems like alot for a one time use .
Old Jun 30, 2008 | 12:59 PM
SBlair's Avatar
The programmer changes your shift points. I got back some pep after the tire change. This is probably the best one on the market. The others do not do as much. If You need to take the rig into the dealer then you swap out the programs and put the stock one back in. Once the dealer is done you load back up the hypertech.
I put one in both the wife's stick and my automatic and it works well in both!
Old Jul 1, 2008 | 05:28 AM
Ghostship's Avatar
"One time use" ?
The Hypertech can be used as many times as you want, on the same vehicle. It is also a code reader.
Old Jul 1, 2008 | 06:13 AM
NE Wrangling's Avatar
Accupro by Hypertech is a simple model as you described and is relatively inexpensive. The Hypertech Max Energy is a programmer that changes also the computer for higher performance from a HP gain perspective.
Old Jul 1, 2008 | 06:28 AM
ursharak's Avatar
how well does it work with a 6 speed? does it really change the engine dynamics ... or do you get most of the help on an automatic.
Old Jul 1, 2008 | 06:31 AM
Offroadme's Avatar
yes i would like to know as well i have a 6spd and im doing a gear swap soon going with 4.88's and i am going to have to re adjust the spedo and stuff i was looking into programmers and would i have to take the jet chip out ??
Old Jul 1, 2008 | 06:34 AM
ursharak's Avatar
I will have 33s, borla dual exhaust, volant cold air intake and throttle body spacer .... what do you guys recommend. Looking for low end muscle, torque, acceleration ...... not really too concerned about the high end ... does that conflict to the new power signature of the dual exhaust, CAI and throttle body? or would it work well with that?
Old Jul 1, 2008 | 06:50 AM
SBlair's Avatar
I can't really say if shift points change in the stick. I drive my Auto most of the time. My wife says that it is peppier than it previously was. The Hypertech helped immensly for low end on my automatic.
Also not mentioned, you put the program on your computer and can get updates. I installed the wifes then when mine came in I did the update and attempted to install in my ultimate. The load was unsuccessful...so I then hooked it back to the PC and it sent the code back to Hypertech. Within a week I recieved a new update which worked. I also contacted them and they were great to work with!
Old Jul 1, 2008 | 07:08 AM
Bodo's Avatar
Originally Posted by Ghostship
"One time use" ?
By one time I meant that once it's set for larger tires, gears etc. that's it until something else changes.
Old Jul 1, 2008 | 07:40 AM
Offroadme's Avatar
hmmmmm this is something i might have to invest in
