add a trunk or flexatrunk
Old Mar 5, 2008 | 10:09 AM
jsmoriss's Avatar
Did I read that the Mopar Add-a-trunk didn't work if you had a the sub-woofer?
js.
Old Mar 5, 2008 | 11:15 AM
az.hunter's Avatar
Default ...
...have you thought about the tuffy trunk...???
Old Mar 5, 2008 | 11:43 AM
JeffreyDV's Avatar
Originally Posted by brando13
How strong is it? Can I stack stuff on top of it? Like a couple cases of beer?
Paperwork says it can support up to 80 pounds.
Old Mar 21, 2008 | 04:48 PM
chodamus's Avatar
Default installation?
anybody have any feedback on installation do's or don'ts? i just purchased one tonight and have heard that it requires you to drill through the floor? anybody?
Old Mar 21, 2008 | 04:53 PM
JeffreyDV's Avatar
The Add A Trunk requires you to drill 4 small holes in the side not the floor. I drilled mine through the carpet. You cant really see the holes if you take the trunk out.
Old Mar 21, 2008 | 04:59 PM
07 RBY's Avatar
Will any of these still work if the rear seat is removed?
Old Mar 22, 2008 | 05:46 AM
JeffreyDV's Avatar
The Add A Trunk will work as it is closed where it meets the back seats.
Old Mar 24, 2008 | 06:38 AM
aphazia's Avatar
Wakerunner, or whomever else has a Flexatrunk-
What's involved with taking out the metal plate that rests up against the seat?
Assuming I need full length with seats down to move something large, what do I need to do to make that happen? How long does it take?
Old Mar 24, 2008 | 06:41 AM
tackindy's Avatar
Ok guys, I need your help! I have the two door JK and took the rear seats out. Will either of these secure the entire rear area or will it stop where the rear seats use to be? I kinda want the entire back end to be covered and secure.
Old Mar 24, 2008 | 06:45 AM
jsmoriss's Avatar
Alright... So I started the install of my Flexatrunk. Here's some info I would have liked to know before buying...
- The metal divider is held by 4 carriage bolts. They would be easy to remove IF they weren't held by the plastic side pieces which strip easily, thus the carriage bolt spins and cannot be un-done, or tightened fully. So far I have 2 carriage bolts that stripped the plastic with little to no effort. One is pretty loose and I can't tighten it further.
- The side pieces are made of flexible plastic which bends as you insert the top pieces. I wish they were made of stronger stuff.
- The Husky liner does not fit within the Flexatrunk's confines, although you can mount the Flexatrunk on top of it. If you do that, then you have to cut away a section on the left so it can bend when you open the cubby.
Well, there you go. I wish Tuffy would offer something like this, but I guess this'll do for now...
js.
