adding a 1inch spacer to a 2.5 coil lift
Old Mar 21, 2011 | 12:36 PM
jtjk's Avatar
Default adding a 1inch spacer to a 2.5 coil lift
i have a six speed manual with a 2.5 coil lift and am wondering if i add a 1 inch spacer in the front i will run into any issues ?
Old Mar 21, 2011 | 01:02 PM
JFRE5H's Avatar
I have this set up, with 1 inch spacers front and rear, and i haven't had any issues. I also added control arms and track bars. My stock drive shafts are failing but i have new ones arriving this week.
Old Mar 21, 2011 | 01:20 PM
jtjk's Avatar
How did the controls arms and track bars improve the ride ? Do u think that is was the extra inch that pushed u over the edge for drive shafts ?
Old Mar 21, 2011 | 02:17 PM
jtjk's Avatar
Bump for answers
Old Mar 21, 2011 | 02:58 PM
Olean NY Jeeper's Avatar
I have RC 2.5 inch coils front and rear with the RC 2.2 shocks on my 2 door. I added a 1.75 inch spacer up front and a one inch spacer in the rear plus coil correction wedges. I ahve very heavy bumper and winch. I have an adj front track bar and rear bracket. No issues except rear DS which I replaced with toms woods.
Old Mar 21, 2011 | 04:17 PM
JFRE5H's Avatar
It rides almost as well as it did off the show room floor (other than the ratcheting noise coming from the drive shafts) The adjustable control arms really allow you to dial in the alignment. If you look on the write-ups thread i believe there is a good alignment thread. I do think i was the extra inch that pushed it over the top. Other people have run 2.5 inch lifts with no issues, but everyones jeep is different.
Old Mar 25, 2011 | 08:58 PM
jtjk's Avatar
will adding an extra inch effect my brake lines at all ?
Old Mar 25, 2011 | 09:06 PM
B09RUBI's Avatar
2.5 inch lift with 1 inch front spacers is what im running so farno issues with drive shafts but brake lines would get to tight on flex for my comfort so installed crown lines no issue with this setup so far. also have sway bar links and rear track bar brace. havent got to the front track bar yet but will soon just for strength.
Old Mar 25, 2011 | 09:08 PM
matt852's Avatar
What drive shafts and size are you buying I'm going to be running the exact same set up.
Old Mar 26, 2011 | 05:36 AM
Bowman's Avatar
I think the brake lines have more to do with your down travel. If your shocks were already at full droop before the spacer and you had no problems, then you should be fine.
