Adding .5" spacers to teraflex 2.5" coil lift question...
Finally getting ready to install my bumper and winch up front on my 2.5" coil lifted JKU Rubi 6 Speed. I am looking at installing the teraflex .5" coil spacers to keep it level after adding the 170lbs to the front and I have a quick question...
Do I need to disconnect the swaybars again when I put the spacers in? Or can I just disconnect the brake line brackets and shocks to let the axle drop? Trying to make this as quick and painless as possible, and it seems like it would be an easy job to pull the springs if you can just drop the axle far enough by removing only 2 shock bolts and 2 brake bracket bolts.
