Additional considerations with TF leveling kit?
Old Sep 22, 2013 | 05:20 PM
warpeg's Avatar
Default Additional considerations with TF leveling kit?
So, a TF spacer leveling kit is on its way to me. I'll be doing the install myself. The actual install seems pretty straight forward from all the research I've done on the forum. However, I have concerns about any necessary next steps after I get the spacers and links installed. Specifically, I am curious about any alignment issues that will need to be addressed. Can you good people of the forum give me a good idea of what alignment or other issues I'll need to have a shop or myself take care of after the install?
Old Sep 22, 2013 | 05:41 PM
jackedupJK's Avatar
I did mine by myself last weekend and I don't think you should need an alignment unless you need one to begin with. I had to adjust my tie rod today because adding the pucks changed the toe and I was getting a little wobble in the steering wheel. Also don't forget to release the lines from their brackets so you can get enough sag in the axle to get the springs out easier.
Sent via digital pigeons
Old Sep 22, 2013 | 05:46 PM
4WheelingAstronomer's Avatar
The leveling kit was straight forward. I took the Jeep to Town Fair Tire for an alignment just because I'm finicky about these things. No issues.
Old Sep 22, 2013 | 05:48 PM
nthinuf's Avatar
Go up to the write-ups area, click the index at the top, and find the DIY Alignment link.
Caster - not adjustable without new components
Camber - not adjustable without new components
Axle centering - not adjustable without new components
Toe in/out - adjustable, but more than likely not needed.
Steering wheel - a wrench and 5 minutes of your time loosening two bolts and twisting the turnbuckle until it's straight.
Soooo ... a wrench and 5 minutes and your alignment is done.
Old Sep 22, 2013 | 05:51 PM
amick218's Avatar
You wasted money on the alignment lol
I almost did the same
Old Sep 22, 2013 | 06:02 PM
gunbo75's Avatar
You do not need a front end alignment just re straighten your steering wheel and that's it
Old Sep 22, 2013 | 06:49 PM
mpullum's Avatar
Just make sure to bring at bolts back to torque specs (control arms after lowered) and check after 300 miles. No alignment needed.
Old Sep 22, 2013 | 07:37 PM
jadmt's Avatar
JK-Forum Ambassador
I had mine put on an alignment table after putting on my tf performance coil kit because I wanted to know what the caster and camber was. both were in spec and they adjusted the toe in which was out of spec by a bit. it was well worth the $50 to know what the caster and camber was.
Old Sep 22, 2013 | 08:10 PM
Ncb's Avatar
Ncb
Loosen the control arms and track bars during the install. Finish the install and when the Jeep is on it's feet give it some good shakes and wiggles and torque all the hardware to spec. Have the toe checked if you wish. If it's out of spec it was out before the leveling kit was installed. Height change won't change the toe.
