ADJ Control Arm Help
So I treated myself to a "Wife is out of the country on work" mod i so frequently get to treat my self to, and got a set of Front Lower Adj JKS Control Arms, and Rear Upper Adj Control Arms, but really, the directions dont seem to help me much about how to properly install them and how to set them right for my current setup (2.5" TF Coil lift, 3/4" Spacer up front). I know my castor right now is 2 degree (which I believe is low), and I want to get my JK to drive nice and smooth
Is there a good write up somewhere that will help tell me how to install them properly (like to make them shorter, longer, a good length to start) or can anyone of you please tell me how to properly install them. I care most for a good starting distance for the JKS ones... Any help would be great.
Thanks
Thanks
Thanks
Thanks
If I were you just start at stock and go from there or 1/8in shorter and shorten in increments, do you have a new rear driveshaft? If it's a stocker, you might not need any adj. Double carden will have to be adjusted so pinion is pointed towards TFcase
Yes, its still the stock drive shaft. I would figure since its an upper, it would be JUST a little smaller than stock (is that right?)
OK, so I got my Front JKS Adj Lower CA's installed. I set them at just under 23", and went and got an alignment. My Castor before the LCAs was "Left Front Castor=2.2" and "Right Front Castor = 2.6"..... Now after the LCAs, you can see my result... Left is 3.2 and Right is 3.9
Can someone that actually understands these sheets tell me what I should roughly do to get the best results now?
