Adjustable Control Arms Jam Nuts
Old 08-19-2016, 07:02 AM
  #21
karls10jk's Avatar
Yep, it makes for quick inspections. It's something I should have done.....and may still do.
Old 08-19-2016, 08:13 AM
  #22
Chuck-The-Ripper's Avatar
Call my crazy but I get them as tight as I can with the joints centered and then put a couple tack welds on each jamnut/arm. When I go to readjust it takes about 5 seconds with a grinder and it's good to go.
Old 08-19-2016, 08:19 AM
  #23
PsychoCupcake's Avatar
Not crazy. In fact a lot of people do that from what I understand.
Old 08-19-2016, 08:35 AM
  #24
kjeeper10's Avatar
Thought about that, at least the lowers. Locked in place use the uppers to adjust caster/pinion.
Old 08-19-2016, 09:45 AM
  #25
Good. I've never heard anyone doing it. I told RK that and they sounded shocked. I didn't feel it being much different than tacking u-joint caps, lol.
Old 08-19-2016, 10:44 AM
  #26
kjeeper10's Avatar
Theyre prob thinking the tack was going to replace 300 ft lbs of torque lol
Old 08-19-2016, 05:24 PM
  #27
matt852's Avatar
Is there a certain sequence to follow front lowers first then front uppers, is is same for the rear? Lowers first then uppers. Had a shop try to do it for me, they didn't do it right as I ended up with 2 deg positive caster and the shop wouldn't stand behind their work
Old 08-19-2016, 06:14 PM
  #28
Typically you want to set your wheelbase with the losers and use the uppers to adjust castor/pinion.
Old 08-19-2016, 06:42 PM
  #29
matt852's Avatar
is it lowers for both for the wheelbase I heard the rear uppers were for wheel base?
Old 08-20-2016, 04:21 AM
  #30
kjeeper10's Avatar
Who you calling a loser? Lol
Correct, decide and set your wheelbase with lowers. I prefer to install the lowers, ensure axles are parallel and square, then hold pinion angle where you want it and adjust the uppers to the mount locations. Torque before dropping the jack. Front you can do easily with the tires on the ground. Rear will need to be on stands with tires removed to gain access to the uppers.
The lowers locate the axles so the settings of each arm are more important. Uppers lengths dont matter as much, setting to the mounts so all 4 bolts slide in/out ensures theres no binding or preload.
Quick Reply: Adjustable Control Arms Jam Nuts
