adjustable front LCA recs please
I have a 2.5 inch Terraflex lift on my 2011 2 door. Getting ready to change out the trackbar and control arm bolts and I figured I would add some adjustable LCAs at the same time to dial in the front end a little. Steering is generally acceptable but just a little skitchy. I am looking for any recommendations based on personal experience for a good set of adjustable LCAs. Thanks.
i too run evo mfg arms but, like BLOTRipper said, why not just get a set of TF? so long as you aren't doing any big flex (the kind you get with coil overs), you'll be fine with them.
Just added Rock Krawler front and rear LCA's last week to mine. Set them up per Rock Krawlers specs, and the thing drives like a dream. These are incredibly beefy, and the bends add a lot of clearance. Rebuildable joints and lifetime warranty as well. A+++
I too have TF 2.5 coil lift with shocks. I also installed JKS Track bar and TF LCA dialed at 23 inches. Both additions has made handling close to stock.
