adjustable front LCA recs please
Old Jan 6, 2012 | 05:22 AM
dgelb's Avatar
Default adjustable front LCA recs please
I have a 2.5 inch Terraflex lift on my 2011 2 door. Getting ready to change out the trackbar and control arm bolts and I figured I would add some adjustable LCAs at the same time to dial in the front end a little. Steering is generally acceptable but just a little skitchy. I am looking for any recommendations based on personal experience for a good set of adjustable LCAs. Thanks.
Old Jan 6, 2012 | 05:58 AM
BOLTRipper's Avatar
I run EVO Manufacturing, but if you like the Tereflex kit you have now why not just do that?
Old Jan 6, 2012 | 06:11 AM
wayoflife's Avatar
JK-Forum Founder
i too run evo mfg arms but, like BLOTRipper said, why not just get a set of TF? so long as you aren't doing any big flex (the kind you get with coil overs), you'll be fine with them.
Old Jan 6, 2012 | 06:18 AM
Ringer's Avatar
Just added Rock Krawler front and rear LCA's last week to mine. Set them up per Rock Krawlers specs, and the thing drives like a dream. These are incredibly beefy, and the bends add a lot of clearance. Rebuildable joints and lifetime warranty as well. A+++
Old Jan 6, 2012 | 09:22 AM
pump2325's Avatar
I just put my OME lift on with TF adjustable front lower control arms and front and rear adjustable track bars. Drives and rides great at highway speeds. Those things are beefy too.
Old Jan 6, 2012 | 10:07 AM
rb0ynj's Avatar
I too have TF 2.5 coil lift with shocks. I also installed JKS Track bar and TF LCA dialed at 23 inches. Both additions has made handling close to stock.
Old Jan 6, 2012 | 10:13 AM
mjones's Avatar
I run TF as well with the same lift. Huge improvement. Passenger @ 23 3/8 and driver @ 23. Helps with jk pulling on crowned roads here.
