Which Adjustable Front Trackbar
Old Mar 6, 2009 | 04:43 AM
SASQUATCH's Avatar
Originally Posted by odin725
Thanks bud, but if you read through the threads TF states the following "$164.49 price is only for the #1753429 sorry no trade in's." The only one I'd consider would be the #1753418 FORGED OVERKILL MONSTER TRACKBAR, their latest model that is designed to work with stock to 6" lifted JK's. So if I read it right I would not have been able to get it anyway for the $164, therefore it's no biggie the sale is over.
Old Mar 6, 2009 | 04:48 AM
SASQUATCH's Avatar
Originally Posted by cvjoint
JKS gets the job done. You should only have to adjust it once when you get the height of your lift right so adjusting it while its still attached was not a selling point for me.
I'm not sure I follow you on this. The lift height is what it is, there is no adjusting the height until I upgrade my lift again. The pic is tiny of the JKS front JK trackbar on northridge's site, so I can't blow it up, but it appears to be adjustable while attached at both points whereby one would adjust accordingly centering the axle to frame , unless I'm missing something. It actually looks near identical to what I've used on the racecar that was fully adjustable while installed on the Camaro, but they called them Panhard rods Vs. Trackbars...same thing.
I'm going to call David @North this morning and get the skinny on TF and JKS fronts, one of them will be ordered soon as they open.
Old Mar 6, 2009 | 05:12 AM
N2MWL's Avatar
JKS front and rear for me, both are quite sturdy and well worth the money IMO......
Old Mar 6, 2009 | 06:28 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Sorry for confusing you on this what I ment to say was the JKS is adjustable you just take one end off adjust accordingly and tighten the lock nut. The terra flex trackbar is designed like adjusting your draglink to straighten you steering wheel you can do it attached to the JK. The JKS trackbar is real easy to adjust.
But you have to take it out to adjust it or just the one end. TeraFlex TB's can be adjust while bolted on the JK at both ends.
Old Mar 6, 2009 | 06:39 AM
joneszj's Avatar
TeraFlex hands down
Old Mar 6, 2009 | 07:22 AM
SASQUATCH's Avatar
Bottom line is the sale you guys ran unfortunately didn't include your HD, sales over anyway, but would have been nice, I'd consider it for $165. Leaving one end out to adjust isn't that big of a deal to me, but I sure liked the TF HD version.
Old Mar 6, 2009 | 07:23 AM
SASQUATCH's Avatar
Originally Posted by rob4607
so what did you get?
They aren't open yet ... and I'm still debating
Old Mar 6, 2009 | 07:43 AM
TeraFlex's Avatar
Just renewed the sale on the #1753429 till the end of the month.
Old Mar 6, 2009 | 07:48 AM
Alaska-HWY JK's Avatar
Default TF HD Trackbar
I have a 3" TF lift and put the TF HD front trackbar on last April or May when they first came out. Have put 20,00km on since with no problems. Easy to adjust and if you get any spring sag or change bumpers or add a winch you don't need to remove it to make adjustments. I always wonder when TF says
4" lift what they mean as thier 3" will net you over 4" in the front.
Old Mar 6, 2009 | 08:46 AM
SASQUATCH's Avatar
Got the JKS from David @Northridge, will be here next Wednesday
Appreciate everyones feedback & help.
