Adjustable rear upper n lower control Arm
Old 10-30-2015, 03:47 PM
SWFL's Avatar
Default Adjustable rear upper n lower control Arm
If I were to replace the stock rear upper n lower control Arms with adjustable ones, would I be able to move the rear axle back a few inches for better wheel clearance ??
Old 10-30-2015, 04:22 PM
shabbernigdo's Avatar
i dont know how many inches you need but yes with adjustable links you can recenter the axles in the wheel wells.
Old 10-30-2015, 04:30 PM
TheDirtman's Avatar
Depends on the arm and more importantly the joint. Something with a Johnny joint or the duroflex will have room to move it back an inch or so. Rk arms would not unless you had custom length arms made.
Old 10-30-2015, 04:43 PM
SWFL's Avatar
I'd be happy with 2-3". Looks like it would cost $400 in parts so I wanted to make sure I would get that much further back.
Old 10-30-2015, 04:46 PM
SWFL's Avatar
I had my eye on the rough country 1137 and 1138.
Old 10-30-2015, 04:53 PM
TheDirtman's Avatar
Your not going to get that much from standard arms. You would need to confirm the amount of threads not the joint shanks. I have measurements for many joints but not RC.
Old 10-30-2015, 04:54 PM
TheDirtman's Avatar
Are you planning on getting a new driveshaft as well? What about coil perches that would no longer be in alignment? Move the swaybar?
Old 10-30-2015, 05:15 PM
SWFL's Avatar
New driveshaft yes and possibly a Dana 60. Just installed teraflex 44 in front with locker n 5.13 gears. Just want those extra inches to go 40's in future. Have tons of space up front now but rear not as much and I've done some cutting.
Old 10-30-2015, 05:16 PM
jedg's Avatar
Your profile says you have 3" of lift and 37s. There's lots of fellas running that combination. Have you done the necessary trimming and set your bumpstops correctly?
Old 10-30-2015, 05:20 PM
Baddkarmaracing's Avatar
Why would Rock Krawler arms not be able to move the axle back? Mine is moved back 2-3" with Rock krawler arms
Quick Reply: Adjustable rear upper n lower control Arm
