adjustable trackbar or bracket
Old Dec 29, 2008 | 02:31 PM
csp's Avatar
csp
Default adjustable trackbar or bracket
Fixing to install 3.5 skyjacker lift kit. Would you recommend using supplied relocation bracket or buy adjustable trackbar. Also do you need anything up front, did not come with anything to relocate. It won't be off-road very much.
Old Dec 29, 2008 | 02:53 PM
BlackNorthernJK's Avatar
Do a search on the forum. Lots of info available. You'll probably find the majority of people will tell you definately an adjustable trackbar, reasons being....the relocation brackets have a tendency to produce too much leverage on the stock mounts causing the welds to break, something you can avoid with an adjustable trackbar
Old Dec 29, 2008 | 03:00 PM
woolf's Avatar
Definitlely adjustable is the way to go for the front. Probably the best decision for the back as well, but I am running the bracket in the rear. I also can fab or weld anything I break, so I can be a little more liberal when it comes to breaking brackets off.
Old Dec 29, 2008 | 03:17 PM
Jusaplaya's Avatar
I am running adjustable trackbar, trackbar bracket, and drop pitman. It is pretty good setup.
Old Dec 29, 2008 | 03:26 PM
wiredawg_mg's Avatar
With 3.5 you will want to do an adjustable trackbar up front. Check with Dave at Northridge4x4.com he can help you out with something good.
I good bracket in the back should work the type that doesn't cuase the bar to act as a lever. Remember the bracket also corrects the trackbar angle in the back.
Welcome to the Forum
Old Dec 29, 2008 | 03:44 PM
woolf's Avatar
Very good point
Old Dec 29, 2008 | 05:02 PM
csp's Avatar
csp
Thanks for the input. I think for now I will go with the adjustable up front and stick with the bracket in the rear.
Old Dec 29, 2008 | 05:46 PM
DeepSky's Avatar
Good choice. This happened to me driving on pavement with a relocation bracket:
The next day I foolishly tried moving the Jeep and the whole thing ripped off entirely and I had to get it towed to the dealership. I have the Skyjacker bracket in the rear and its seemed to hold up just fine after 18k miles.
Old Dec 29, 2008 | 05:52 PM
White Widow's Avatar
go with the adjustable track bar brackets suck
take my advice dont bolt on to bolt on stuff
Old Dec 29, 2008 | 08:35 PM
wildkcars's Avatar
I have the same kit. The back bracket is really durable and you do not have as much side to side force in the rear. The front go with an adjustable I tried messing with moving mine to other holes and drilling the front bad idea. I now am going with the adjustable up front. Do it now before you break it and have to do it anyway.
