Adjustable Traction Bar to long?
Old May 18, 2008 | 01:20 PM
muddpuppy01's Avatar
before you put the trac bar on where you off on the driver side
Old May 18, 2008 | 01:24 PM
xldme's Avatar
Yes, but it was off by a little over 1/4 of an inch. I was better off with the stock track bar.
Old May 18, 2008 | 01:26 PM
yup you need more lift then to push it to the drive side then 3" springs should do the trick other wise I would put the stock bar bak on
Old May 18, 2008 | 01:31 PM
xldme's Avatar
THX. I should of just left it alone. Oh well, anybody wanna buy a track bar? It will be on the for sale page pretty soon.
Old May 18, 2008 | 03:25 PM
Screamin Lizard Customs's Avatar
Sponsoring Vendor
To really set the front trac bar, it needs to be set on an alignment machine. Adjusting the heim in or out 1/8" can change the trust angle 10 degrees. Do you have a rear adjustable trac bar?
Old May 18, 2008 | 04:35 PM
Originally Posted by xldme
Superlift
Ive got a 2.5 bb and 3/4 leveling spacer. It was off a bit with the stock traction bar so I ordered the adjustable. Now its worse. I think they are right It's not enough of lift.
ive got 2.5 inch springs and the 3/4 inch leveling spacers with a havy bumper and heavy winch so mine sits low
i also have the uperlit track bar, its screwed in all the way and my wheels are perfectly even on both sides
i would say that if you dont have a winch or bumper then you should have some adjustability
Old May 18, 2008 | 04:36 PM
greasemonkey85's Avatar
i can tell you exactly why it is off..... the superlift trac bars are for their 4" kit or any 4" kit. my brother inlaw (muddytoy) has the teraflex BB and can t even tell the axles are off. i had the skyjacker BB and now the skyjacker 4" kit and i got 5" out of it and my trac bars will be here in afew days. it is really bad now that i have the new lift on.
Old May 19, 2008 | 01:26 PM
xldme's Avatar
No, a traction bar relocation bracket from TF
Old May 19, 2008 | 01:29 PM
xldme's Avatar
If thats the case then a certain jeep parts supplier should change the wording on their website. It clearly states for jeeps with 2 to 4 inch lifts.
http://www.4wd.com/productdetails.as...39&partID=9005
Old May 19, 2008 | 01:31 PM
xldme's Avatar
Update
I've removed the adj traction bar and installed the stock bar. It is now back to where it was out of adj to the drivers side around 1/4 on inch. Which by the way rides alot better than with the adjustable bar.
