Adjusting Headlight with big lift
Old Apr 22, 2009 | 12:27 PM
Bigshow's Avatar
Default Adjusting Headlight with big lift
I have a 6.5 inch lift with 37's I am going to adjust the headlights tonite after blinding half of my town over the last few weeks. does anyone running high know if the adjustments go that far on the screw or is there some sort of kit i have to buy to adjust practically straight down?
thanks
Mike
Old Apr 22, 2009 | 01:38 PM
You'll be just fine, no kit necessary. Follow the very good write up in the Electrical section and it's a snap.
Old Apr 22, 2009 | 04:04 PM
joneszj's Avatar
Slight hi jack here...but I installed an aftermarket bumper that incorporated the factory fogs, but now they shoot up higher than the actual headlights. I don't use them a ton but when it gets real foggy where I am in PA they are necessary.
**Anyone know how to adjust the trajectory of the fog lights? I tried to bend the bracket they mount to, but that didn't work. Need some suggestions
Thanks for any help
Old Apr 22, 2009 | 04:12 PM
joneszj's Avatar
So I found an old thread about adjusting the fogs, anyone know for sure which Torx head it takes to adjust them?
Someone out there has to have adjusted their lights, let me know. Thanks again
Old Apr 22, 2009 | 05:19 PM
speedbagger's Avatar
i wouldnt adjust them straight down....you'll lose alot of night vision.
if they were adjusted correctly to begin with, i'd just tweek them down a little.
