Advice on tires needed
Old Aug 11, 2014 | 06:58 AM
jbaubry's Avatar
I like my General Tire Grabber AT2 275/70R18 on JKU.
Quieter then the stock, handle pretty well and very good under heavy rain. Can't comment yet on snow or offroad.
Were very affordable too.
Old Aug 11, 2014 | 09:37 AM
RockinRobin's Avatar
Here's a plug for the Toyo ATll. I ran multiple sets on my pickups. Put 12.50 35 17 on my jeep. Love them. Quiet, aggressive look for an AT. Must air them down though E range tire. Im still play around but at 32 lbs now.
Old Aug 11, 2014 | 09:42 AM
jeepJK199's Avatar
Originally Posted by webejeepin
OP, we have similar driving styles, which is why I talked myself out of the MTZ's....tough call at the time. I went with the Mickey Thompson ATZ (realize they may be discontinued) they have great agressvie looks, no issues in the light trails I do, and in the snow this past winter have been great. They also have a nice hum to them.
AND, they are wearing very well....with 40,000KMs on them, 5 tire rotation every 5,000KM...think I've burned up 3/32" thus far.
Loos like the replacment tire is the ATZ P3, no personal experience with them other than to see a few jeeps running around on them.
You may want to add these to your comparisson shopping list.
I second this recommendation although they have gotten noisier as the miles have racked up. I have 20,000 miles on mine and are still in excellent shape. The old ATZ's are discontinued which is very unfortunate because their looks were second to none. The new ATZ P3 looks like a great tire and looks to be a bit mellower in tread design, which would benefit noise levels. I was considering some MTZ's this past summer but after hearing many complain about the noise level, I held off.
Duratracs are a great recommendation. They are quiet and last a long time. My buddy has them on his Ram and he swears by them. Not my favorite in terms of looks though.
Old Aug 11, 2014 | 09:57 AM
maxspongebob's Avatar
Originally Posted by AnvilX14
Duratrac. I'm not sure if you would call it a conventional tread, but they are a great all around tire and I think pretty quiet too.
Agreed. Goodyear Duratrac is a great tire, it is a very good compromise between highway and off-road driving qualities. When I put them on my Jeep they were more quiet than the stock tires were. However, most of the "quiet" comes from softer rubber and therefore the tire will probably not last as long on the street. Rotate them often, including the spare, to help minimize uneven wear.
Old Aug 11, 2014 | 10:38 AM
JK_Convert's Avatar
Duratracs would be my rec too. Ran two sets. On this set of 35s I've picked up 2 nails in 3k miles. Either I'm unlucky or they aren't very strong.
Old Aug 11, 2014 | 04:04 PM
webejeepin's Avatar
I've owned my share of vehicles and have purchased tires for them over the years.
However, tire shopping for a Jeep was the most involved, researched, analyzed, debated, questioned and stressful decision of all them.
So many things to consider:
-2 or 4 door
-weight of the Jeep
-trail type vs on road use
-will you tow with it
-how much weight you towing
-wheel back spacing
-stock suspension or lifted
-how much lift
-consideration for snow, slush and ice on road
-number of miles you drive per year
-size both height and width
-in some cases gearing
-in some cases auto vs stick
-In some cases 4 speed auto or 6 speed auto
-personal preference on looks, manufacture
-raised outlined letters or not
-load rating
-sidewall plys
At the end if the day be 100% honest with yourself, and what you will be using your Jeep for. Do your homework, ask lots of questions and go and see and feel the tires side by each if you can in a shop.
Most Jeepers when asked at random on their tires will tell you what they think.
Recommendations of tires on this thread are solid ones don't think you can go wrong.
I do think complaints about tires as their poor performance comes from folks may not have done their homework and or selected a tire that did not match their Jeep and how they use it 95% of the time.
Happy shopping, once you've decided....happy wheeling!
Old Aug 11, 2014 | 10:10 PM
Matthewd5's Avatar
I've had Duratracs on a couple of Jeep's and I've had great luck, especially the snow
i only went to mtrk's when I got 37's
matthew
Old Aug 12, 2014 | 12:27 AM
Mountain Man Tim's Avatar
-2 or 4 door
-weight of the Jeep
-wheel back spacing
-how much lift
-load rating
-sidewall plys
At the end if the day be 100% honest with yourself, and what you will be using your Jeep for. Do your homework? Ask lots of questions and go and see and feel the tires side by each if you can in a shop.
Most Jeepers when asked at random on their tires will tell you what they think about their rigs and tires.
I do think complaints about tires as their poor performance comes from folks may not have done their homework and or selected a tire that did not match their Jeep and how they use it 95% I the time.
very well said.
Old Aug 12, 2014 | 01:42 AM
Mark Doiron's Avatar
I'm on my second set of Duratracs. The sidewalls are not as strong as some brands, which did contribute to my puncturing one last year. Fortunately, that tire was near end of life. They are quiet on the road, and amazing in sand and snow. And they have a pretty aggressive look for an AT ...
Old Aug 12, 2014 | 04:33 AM
CerOf's Avatar
Mark, How many miles did you get out of the first set?
I'm big on BFG if for no other reason than how long they last. Including the stock rubicon BFGs and my current BFGs, I've driven 112,000 miles. They'll go another 10k.
Sent from some string and a few tin cans.
