AEV 2" spacer lift+ geo brackets?
Old Jul 13, 2013 | 02:11 PM
Logan1982's Avatar
Default AEV 2" spacer lift+ geo brackets?
Hey guys! Was just looking to get 2 inches of lift on my new 2013 jk sport hard top and was wondering if I would be able to use the AEV geo brackets with their 2" spacer lift to adjust the castor. I know there's a slot for the 2.5" lift and was going to use that. Do you guys think I can run this setup? I'm not going to add any extra weight in the future so will be running light. Any advice would be greatly appreciated.
Old Jul 13, 2013 | 02:56 PM
JKRescue08's Avatar
You can run the brackets on the 2" but in my opinion it wont make a difference. I had em on with my 2.5" and did not notice any difference at all. Once I put on my 3.5" lift, I ran it without the brackets and then put them on - hell of a difference.
They dont do alot on a smaller lift and are not necessary.
Old Jul 13, 2013 | 02:59 PM
Logan1982's Avatar
JKRescue08 thanks for the response!
Old Jul 13, 2013 | 04:51 PM
Freewill's Avatar
The brackets WILL make a difference. . . its a question of whether you NEED the difference. Lot of folks run 2.5" of lift without any geometry correction and like it fine. Others choose the brackets or adjustable control arms.
But seriously, for the same amount of work it takes to install spacers you could install 2.5" springs and have a much nicer suspension. Think it over and save up a few more bux while yer thinking.
Old Jul 13, 2013 | 04:58 PM
supperfast's Avatar
I just installed the 2" spacer lift and 33's and it rides fine..
Old Jul 13, 2013 | 06:59 PM
DKehler's Avatar
On aev's website click on the brackets and you can view the instructions. They have measurements for which holes to use and do not recommend using them if your under a certain height. I have a 2 /2" spacer up front and don't quite meet the specs.
Old Jul 14, 2013 | 07:33 AM
Logan1982's Avatar
Thanks again guys for the advice. Freewill, I think you have a good point. I might as well just wait and save up. How is the ride though with the 2.5" lift and stock bumpers? I'm not going to add any weight in the future. Maybe the OME Light Duty lift would be better????
Old Jul 14, 2013 | 08:04 AM
jadmt's Avatar
JK-Forum Ambassador
What size tires are you wanting to go with? I think tire size is a big factor in lift size. If you want to run 33" just run a 3/4-1" spacer. If you want 35 or bigger a real lift is necessary unless you want to run flat fenders.
Old Jul 14, 2013 | 09:16 AM
Logan1982's Avatar
Jadmt just 33's. I just keep hearing how AEV's suspension lifts ride better than stock. Maybe I'm over thinking. Lol
Old Jul 14, 2013 | 09:40 AM
Freewill's Avatar
The ride with AEV 2.5 springs is great both on and off road, but my JK is heavy with mods, tools, gear, and hardtop. I agree the OME light springs could be perfect with stock weight. Recommend OME shocks if you use their springs. Geometry correction can be done later if you don't like the steering feel.
