AEV Bar what is e-coated?
Old Jul 25, 2007 | 01:13 AM
daveaus's Avatar
Default AEV Bar what is e-coated?
Hi,
Can someone tell me how the AEV bar comes when you order one does it need to be painted? The site says it is e-coated what is this? Thanks
Old Jul 25, 2007 | 05:16 AM
RotorHead's Avatar
What bar do you mean?
Old Jul 25, 2007 | 08:26 AM
Rubidon's Avatar
Originally Posted by terrahawk
Fancy way of saying it is primed.
Not exactly .........It is a dipping process, and is very resistant to rust.
Old Jul 25, 2007 | 03:31 PM
101gargoyles's Avatar
Former Member
The E-Coat system is used by all vehicle manufacturers to prime bare metal (body-in-white) assemblies prior to colour finishes.
It's a multi stage way of electrically bonding zinc/resin based primer to a thoroughly cleaned surface.
This is the system which make bodies last longer even though the newer high tensile sheet metal is thinner and therefore lighter.
Any part purchased already E-Coated is probably visible when installed and will require professional painting.Talk to the body shop guy whether it's best painted on or off of the vehicle depending on the type of fasteners being used.
