AEV drop brackets.
So I purchased these brackets to see if it can help with my rough ride. Went to put them on and can't get the stock bolts off. Any tips? I tried pb blaster and a breaker bar. No luck. Also will I need any alignment after these?
I'll post reviews when I finally figuure it out.
are you having issues due to rust? because you really should be able to free up your control arm bolts with the breaker bar you have. try slipping a pipe over the end of it to give you more leverage.
Get your ass under that bar. Use your frame as leverage with your legs and PUSH or PULL. Try different ways, you should be able to get it. At 135 lbs, I've broken nuts, bolts, sockets, and wrenches. You can do it, just find the right leverage points.
you'll forgive me but, your ride is very comfortable due to the OME coils and shocks. the OP is having issues with the harshness of his ride and it is these things that would really help him.
2 cents from the peanuts gallery
