AEV lca brackets???
on the aev-conversions forum i saw a post that broke down the lift range in inches that the drop brackets would work with. I forget the exact numbers but the measurements were based on the diustance between the frame rail and bump stop pad if i remember correctly. So basically if your measurements fit this range the brackets would correct the caster appropriately. The numbers were put together by aev, so even if you cant find the post, you could give them a call.
I am running these brackets with a 2.5" lift and love them. I thought it drove good before I put the brackets on.(I done some trading with a guy that put a new lift on and I got the brackets right.)But after I put them on it was a night and day differance. I really recomend them.
https://www.jk-forum.com/forums/show...aflex-2.5-lift
Thanks for the link blue project. I tried to search for that thread before I started this one but couldn't find it. I figured for $100 these brackets would be worth a shot. I dont have a lift yet but these brackets sound like they could correct castor and prolong the use of the stock front driveshaft?
