aev lift
Old Feb 14, 2012 | 03:14 PM
jacksjk's Avatar
Default aev lift
Hello all ! And thanks for reading . I am buying a 2012 jk 2 dr sport w/ auto trans , and i plan on lifting it and running 35's . I plan on buying the aev dualsport sc system with shocks ,. I have a couple of questions for anyone who has this setup . First , how is the installation ? I plan on doing it with a friend and we are both ok experiencewise . Also the kit comes with a procal programmer , i'm not sure i know exactly what this does , will i need to change gear ratios to run the 35's ? Or is that what the programmer takes care of ? Or will i be ok with the stock gears . Thanks
Old Feb 14, 2012 | 07:22 PM
BKC MT JEEP's Avatar
Jakes jk,
You will like this lift the install is about 8 to 12 hours the pro cal is to reset your speedo and set your tires size to restore your shift points
Old Feb 14, 2012 | 07:39 PM
DelmarvaJK's Avatar
Love my 3.5" AEV SC lift, perfect for my 80% street 20% wheeling... Well designed product, very smooth ride both off road and daily driving... On road charateristics are just as good as off road! Well balanced system, not over done! And the Bilstein 5100 shocks make the ride comfortable while maintaining great handling on/off road!
Big thumbs up from me!
I'm running 17" AEV Pintler's w/ 35" MT Baja ATZ's... Love the combo!
Old Feb 14, 2012 | 07:54 PM
RUBINOT's Avatar
Procal module is great. I just used it to set my speedometer. Very easy to use and is very accurate.
