AEV procal and gear ratio setting
Old Jan 5, 2012 | 05:00 PM
scrappy's Avatar
Originally Posted by Hifirush
How about the tpms adjustment how far can we deflate the tires?
you can set the tpms adjustment as low as you want, down to 0.... tho that would probably not be optimal tire pressure
Old Jan 5, 2012 | 05:40 PM
bingote's Avatar
Guys, is there any use for the aev procal in a stock JKU with only a 2" lift?
Old Jan 6, 2012 | 05:44 AM
hneiper's Avatar
If you changed tire size and/or gears then it's useful otherwise I suspect it wouldn't be of much use.
Old Jan 6, 2012 | 06:09 AM
bingote's Avatar
Nah... Just the lift... Thnx
Old Jan 6, 2012 | 06:15 AM
tslewisz's Avatar
It's optimal if you don't have TPMS sensors any more!
Old Jan 6, 2012 | 06:21 AM
MossGaBoss's Avatar
i you had a winch you could idle up during long winching runs.....help keep your battery healthy.
Old Jan 6, 2012 | 06:26 AM
hneiper's Avatar
Good point!
Old Jan 6, 2012 | 07:21 AM
hneiper's Avatar
Anyone know if the reprogram of PCM will overwrite the Procal settings? Just had it done and was wondering.
Old Jan 6, 2012 | 07:46 AM
tslewisz's Avatar
No, they are not over written.
Old Jan 6, 2012 | 08:04 AM
hneiper's Avatar
Excellent!
