AEV ProCal - settings not staying?
Old Jul 26, 2011 | 08:06 AM
JGP4JK's Avatar
Default AEV ProCal - settings not staying?
Have any of you using the AEV ProCal device had problems with the settings going back to factory after a while? I have set my tire size using the device and for a while it shifts correctly and runs great, but after a few weeks the shifting gets bad again and I have to plug the AEV device back in to set the tire size again. This is happening with my tire pressure as well. I recently set everything back to factory and started over, even going as far as making sure the correct gear ratio was programmed in. Hopefully this will do the trick but i wanted to see if this was an isolated incident. Thanks in advance for feedback.
Old Jul 26, 2011 | 08:15 AM
Northridge4x4's Avatar
Sponsoring Vendor
I have never had this problem . I have programmed about 500 JK's with the procal.
David
Old Jul 26, 2011 | 08:41 AM
JGP4JK's Avatar
David
Yeah i would not think that this would be an issue. Definitely a head scratcher. Thanks for the response.
Old Jul 26, 2011 | 08:44 AM
Sponsoring Vendor
Are you cycling the key after every change?
David
Old Jul 26, 2011 | 08:47 AM
D_engel's Avatar
When i first reprogrammed my tire size and tpms on my JK, i lost all funtions temporarily. No speedo, no tach, and a glaring check engine light. I reset it to stock, tried again and ive never had any problems since than. Sorta strange
Old Jul 26, 2011 | 09:39 AM
JGP4JK's Avatar
Okay, thats what i did this time so hopefully that does the trick. Thanks!
Old Jul 26, 2011 | 09:41 AM
JGP4JK's Avatar
David
Hey David, yeah I sure did. For every change i shut it off completely and then back on to make the next change. I tried the idea to reset back to factory and then start again so we will see if that works. Thanks again.
