AEV Procal and TPMS Issue
Old Jan 14, 2012 | 12:35 PM
fifthconspiracy's Avatar
Unhappy AEV Procal and TPMS Issue
Searched and couldn't find my exact problem... so I thought I'd put this out there before contacting AEV.
2012 Sahara Unlimited, Manual 6spd.
AEV Procal for 2012
Did the following:
1. Tire Pressure threshold set to 20psi on the dip switches (and yes, was holding it the right way, switches are correct).
2. I turn the key to ignition, the engine lights come on for a second etc. etc.
3. I plug the Procal into the port, horn honks immediately twice. the seatbelt light flashes twice as well and the low tire warning flashes the words "low tire" and the icon lights up for second.
4. I turn the key to full off position.
5. I unplug the Procal from the port.
Should be good right?
I then let the air out of a few tires down to 10psi. Leave it like that for a bit, drive a short distance on my property.
Still no TPMS light comes on. It's like it's basically just fully "off" now and the threshold settings do not work. I tried some further psi settings and still nothing.
From the other threads I read, I followed the proper procedure of leaving it plugged in until you turn the ignition to off and remove the key. But still the light will not come on at a psi lower than the threshold.
Ideas?
Cheers! ~ Paul.
Old Jan 14, 2012 | 03:49 PM
jkjacksonjack's Avatar
When I did mine I did the following:
1. turned the key on
2. plugged it in
3. the horn beeped twice
4. unplugged it
5. turned the key off
I looked at the manual and it said you had to turn the key off before you start the vehicle. Not before you unplug it.
When I put my new wheels and tires on it they didn't even have the TPMS units in them. I drove 30 miles before the light came on.
I just set it to zero. I couldn't see the point. If I set it to 20 the light would still come on every time I aired down. If I left it stock, the light would come on every time I aired down. Since I usually drop down to about 11-12 lbs when I offroad it would come on. If I set it to 10 lbs I would practically have to have a blowout for it to go off. If I had a blow out I don't need that little light on the dash to tell me
Old Mar 19, 2012 | 05:22 AM
MtraXX's Avatar
Somewhat of the same issue. I set the pro cal at 26 psi and I'm running 29 but the light wont go off.
Followed the same instructions,
1- ignition only on
2- plugged in pro cal
3- horn honked twice
4- removed procal
5- turned key off
6- turned ignition on
7- drove a bit and light wont go away
Old Mar 19, 2012 | 03:14 PM
hibypass's Avatar
What is the factory setting for the TPMS to come on? PSI that is
Old Mar 19, 2012 | 04:42 PM
snytribe's Avatar
I have a 2010 and 285/70R17 with #40. Light has not come on. Did you get an older model that is not set for 2012's. On the outside of the box mine said it was good to use with 2012.
Old Mar 19, 2012 | 07:23 PM
Athens_JK's Avatar
There is a new post today on this same issue that could help you out.
Old Mar 20, 2012 | 02:00 AM
Pimpin's Avatar
1- ignition only on
4- removed procal
5- turned key off
I'm pretty sure you need a 5 psi deviation . so if you run at 28 psi . your procal needs to be set at 23 psi. that should keep your light off..
Old Mar 20, 2012 | 06:25 AM
MtraXX's Avatar
something worth to try, thanks!
Im at 29, have it set to 26. I'll set it down to 24 and see what happens...
Old Mar 20, 2012 | 06:51 AM
WSU 5.9er's Avatar
I bought some takeoff tires and wheels from an older JK and put them on my '12 JKU. It took 40 miles before the TPMS light came on. I used the AEV procal to turn off the TPMS stuff completely.
Old Mar 20, 2012 | 08:38 AM
Pimpin's Avatar
any luck??
