aev procale module question? need help
Old Feb 8, 2010 | 04:11 PM
REDJK21's Avatar
Default aev procale module question? need help
If anyone has this item....I have a concern on how to fix the low tire pressure threshold. It all seems straight forward i just think im doing something wrong. i set all four of my tires to 34 psi for my comfort. How do i set this up? can someone give help?
thanks
Old Feb 8, 2010 | 04:48 PM
PGCI's Avatar
It suggests setting the monitor to 4 PSI below where your tires are set. So set it to 30 psi, insert the module, and the horn should honk. After that, go drive it a mile or two, and the low tire light should shut off.
Old Feb 8, 2010 | 09:52 PM
spinlock's Avatar
As described above, you select the threshold air pressure on the Procal which triggers the tire pressure warning, not the air pressure you set your tires to.
The recommended pressure difference is 4 psi but if you air down frequently, that is a bit on the sensitive side, so I usually set mine to 6-8 psi.
Old Feb 9, 2010 | 12:40 PM
REDJK21's Avatar
got it to work.. thanks guys
Old Feb 9, 2010 | 01:10 PM
bcboy1969's Avatar
Can you turn it right off? I don't wanna put the tpms back in with my new rims,
Old Feb 9, 2010 | 03:42 PM
RubiBurst's Avatar
Yes you can. I did that when I swapped my wheels from my 07' X to my 09' Rubicon. Works like a charm.
Old Feb 9, 2010 | 04:54 PM
REDJK21's Avatar
Ya you can. Its sweet no more dinging shit and bright orange light in your face. Very straightforward to use i just wasn't following procedure.
