AEV Snorkel Install Question
Old Jul 26, 2012 | 02:50 PM
Gman*2007's Avatar
Default AEV Snorkel Install Question
I'm getting parts rounded to install a snorkel on my 2012 JKU and was wondering if replacing the factory air filter element with the K&N was a good choice. From the info I got from other threads, its not advisable to install a CAI along with the snorkel. Also should I run it dry or oiled & will I gain any HP or MPG's? I'm also extending the breather hoses to make it water proof. All info is appreciated.
Old Jul 26, 2012 | 08:15 PM
jeepwave's Avatar
I'd like to see everyone's answer on this
Are you cutting your hood or did you get the Aev heat reduction hood?
Old Jul 26, 2012 | 08:49 PM
afpilot82's Avatar
JK-Forum Ambassador
I didn't think AEV had a snorkel compatible with the 2012 yet. I replaced my stock filter with a K&N on my 07 with the snorkel, no issues.
Old Jul 27, 2012 | 07:41 AM
Gman*2007's Avatar
Yes, I am cutting the hood myself. After I mounted the Or Fab tire carrier and drilled the hole for the landing dock, that took all the worries out of cutting sheet metal. It's actually pretty easy as long as you take you time and measure twice.
Old Jul 27, 2012 | 07:43 AM
Gman*2007's Avatar
Quadratec will have them available August the 1st. Mine has been paid for and I'm just waiting.
Old Jul 27, 2012 | 07:46 AM
pastorwug's Avatar
Just in case you didn't read an earlier response - the AEV Snorkel does not fit any 2012 JK.
From their site:
JK Snorkel Kit
*NOTE: The AEV JK Snorkel Kit is not currently compatible with 2012 gasoline powered Wranglers.*
Make sure you don't cut your hood before checking everything first - the air box on the 2012s are completely different than the earlier JKs.
Old Jul 27, 2012 | 07:50 AM
Gman*2007's Avatar
From their site:
JK Snorkel Kit
AEV had to redesign the snorkel to fit the 2012 air box. Quadratec is taking orders for them and should be shipping out on the 1st, is what I was told.
Old Jul 27, 2012 | 08:21 AM
Shoup's Avatar
I installed mine a few years ago, and switched to the K&N filter. I also ordered both the ram air and pre-filter tops.
Old Jul 27, 2012 | 08:28 AM
Shoup's Avatar
https://www.jk-forum.com/forums/memb...2-albums-jk-2/
Old Jul 27, 2012 | 08:37 AM
jeepwave's Avatar
I plan on doing it aswell was just wondering so I could see photos once you were done.
