Is AEV worth the money?
To throw in my2 cents, and I am by no means an expert, AEV has very good ride qualites my all accounts, but my opinion is that it is too expensive for what you get. As has been said, for a few hundred more you can get the full traction ultimate kits.
I spoke with Dave at Northridge today, and what I have decided to get is the Northridge Old Man Emu Long Travel JK Lift Kit. The package comes with HD springs, long travel gas shocks, adjustable front and rear traction bars, adjustable front and rear sway bar links, extended brake lines, bump stop extentions, and adjustable front lower control arms.
That seems to be the perfect package for my needs
Ive done a ton of searching and as much as I hate to break in steps here is the build:
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
AEV premium front bumper
Warn m8000
5.13 gears
Prob a smittybilt rear bumper/tire carrier
Ill do wheels, tires, lift, and gears at the same time (soon). Then I'll worry about the bumpers and winch.
Most of my off roading will be mountain roads, snow trails, expedition driving. I dont play in the mud and not too fond of rocks after a land rover incident I had.
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
Warn m8000
5.13 gears
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
Warn m8000
5.13 gears
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
Warn m8000
5.13 gears
--Edit-- I actually have not had the time to read the entire thread but here is a few things below
Well I just had a long reply typed out and the phone rang and I closed it on accident .
Bottom line the AEV kit is a very nice kit. In my opinion one of the best riding kits available. Is it for everybody no. Is it for the 90% Daily driver occasional weekend warrior yes.
It comes with everything you need except wheels and tires. Is it expensive - well its not cheap.but I dont think it is overpriced. Its made in america and is probably the most engineered 3" lift on the market.
I like the Fact that nothing is adjustable and it works great right out of the box. For the novice installer it makes the install very easy. No measurments to be made nothing that you can screw up.
I liek the drop down brackets 1000x better than cam bolts , but the drop down brackets are not for everybody if you wheel it hard and in the rocks get some front adjustable arms.
The OME 3" Long travel kit and The AEV 3.5" kit all have there place and customer but I think the two customers are different if that makes any sense.
I am probably not making much sense I am typing between phone calls
If you have any questions please feel free to give us a call.
Thanks
David
Thanks
David
i will say one thing about aev, they do an outstanding job of marketing and if they can get people to enthusiastically pay as much as they do for a set of brackets, more power to them for knowing how to make an easy buck.
check it out, you can get the off road evolution track bar relocation bracket/drag link flip kit and it does everything the aev steering correction does and for only $299. in other words, for about the same price as an aev kit, you can get the northridge4x4 OME kit and have the exact same handling as the aev kit AND, have real heavy duty adjustable track bars and adjustable heavy duty front lower control arms instead of a just a set of non-adjustable brackets.
EVO JK Draglink Flip Kit When lifting your JK 3” or greater, it is highly recommended to correct some of the steering geometry that has been altered with the lift. The EVO JK Draglink Flip Kit does just that and more. · Raises trackbar mounting location 3” at the axle to help correct roll center and steering angles of a lifted JK.· Roll center is greatly improved giving better handling of the vehicle on and off road· Complete bolt-on design that gives greater strength to already prone to failure factory front trackbar bracket· Comes complete with new forged draglink· All bracketry made from 3/16” thick laser cut and CNC bent sheetmetal· All bracketry is finished in a corrosion resistant Black Powdercoat Notes
rilling of the passenger side steering knuckle with 7/8” drill bit is required to complete the install $299.99 Thanks,Andrew PerleProduct EngineerEVO Manufacturing Inc.PH:714-870-5515FX:714-870-1130 www.evomfg.com
This is the same with any lift kit. If you gave me the measurements off all the pieces of any lift kit on the market I could make you the exact same thing in my shop for probably 1/4 of the price that you purchased it for. There's a lot more in the price then just the material.
To be fair to AEV they seen to have a lot of time invested in the design of the kit. Otherwise it would not handle as well as it does on the pavement. That R&D time costs a TON of money and that is most likely what you are paying the "inflated" price for. I deal with it in my industry all the time. We sell the customer a product for $10k and there MIGHT be about $1000 - $1500 of material cost in the price. The customer realizes this and gets pissed and claims we are ripping them off. Then you have to explain to them that the rest of the money is in the manpower that it took to design and set up that $1500 worth of material.
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
Warn m8000
5.13 gears
AEV 4.5 premium
AEV Pintlers
37" MTR kevlar
Warn m8000
5.13 gears
