After Evo gussetts and sleeves?
Old Oct 9, 2009 | 11:19 AM
qzing01's Avatar
Default After Evo gussetts and sleeves?
I just recentley had the Evo sleeves and gussetts along with there control arm skids installed. When I got the jeep back I get a little "more" wobble when I am around 45mph and again around 60 to 65mph? Before I had this done I would get a little wobble around 45mph. I knew my aligment was off just a bit and was going to have one done anyway after the install. It seems to be worse now. I am wondering if I just need to check into more than the aligment. Could something else have happened to cause this?
I have adj uppers on the front running 35's
Old Oct 9, 2009 | 12:01 PM
wildandwillin's Avatar
If the shop pulled the ball joints and arms I would be sure its all back together properly and torqued.
Old Oct 9, 2009 | 12:07 PM
qzing01's Avatar
Default sleeves
I dont think they did, but I am not sure.
Old Oct 9, 2009 | 12:15 PM
If they didnt pull the ball joints and didnt take care not to over heat the area you could have heat damage
Old Oct 9, 2009 | 12:32 PM
sounds like you have a problem but can't see how the c's and sleeves could be the cause.
