Air Locker
Old Mar 23, 2009 | 07:28 PM
tento0929's Avatar
Default Air Locker
Hi
I want to put some rear air lockers, what do you recomend???
i was looking for arb but i dont know what do you think?
they told me not to put air lockers in front because i could break the drive shaft, is that true??
how do i know which dif type do i have dana 44 or dana 35 rear????
Wrangler X 2008 2 door.
thanks
Stefano T.
Old Mar 23, 2009 | 07:41 PM
wayoflife's Avatar
JK-Forum Founder
arb's are a very good locker and they are air actuated. if you plan on running only 35" tires, you should be fine with an arb up front so long as you upgrade your axle shafts to chromoly. being that you have a 2008 X 2-door, you will have a dana 44 rear and dana 30 front.
Old Mar 23, 2009 | 07:59 PM
tento0929's Avatar
im going to buy 33's because i use my car to go traveling they tell my that 35' not good for the road, and this week im installing a kit that i bought 3' full traction premium whith m-force gas shoks.....
Old Mar 23, 2009 | 08:02 PM
wayoflife's Avatar
JK-Forum Founder
well then, you should be fine with a set of ARB's then.
Old Mar 23, 2009 | 08:03 PM
tento0929's Avatar
so if im going to put some front air locker what axle shaft do you recomend or do you think are good???
Old Mar 23, 2009 | 08:09 PM
wayoflife's Avatar
JK-Forum Founder
i'd recommend alloyusa shafts as they come preassembled and do not require you to replace the inner seal.
Old Mar 23, 2009 | 08:15 PM
bigbluejk's Avatar
Who is the "they" that said 35s are not road worthy but 33s are? You know that both sizes come in more highway acceptable tread patterns, don't you? Like you can get an all terrain or all weather tire instead of a Mud terrain and get much better performance. I would say a 35" A/T is much better on the road than a 33" M/T. If you are referring to gears, and you have 4.10s, and you are not willing to regear 33s are much better than 35s. think hard and get the size you want or you will regret it!
