air pressure for km2 35in
For highway driving what are you guys with km2 35 in or similar set your air pressure at. my dash shows 50lbs 48lbs . it sure makes for rough ride. Whats a good median for comfort and tire life? this is what the tire shop put in, i thought it seems alittle high.
russ
russ
haha yeah do yourself a favor and get some air out of those!!! What width wheel are you running them on, that makes a difference. Skinner the wheel the less psi you need for that ideal even contact patch. I'm running 35x12.5x15 km2's on 15x8 wheel at around 28-30 psi. I have never done chalk test or anything, but that's been the general consensus on a good range
Your ride will improve greatly compared to 48 psi
wow that explains the rough ride.
so how do you do a chalk test? I assume it is done to make sure the entire tread is making contact with the ground.
Im running these on factory 10th annivesary rubicon rims. i thank they are 7.5
russ
russ
