Airing down???
Old Jul 28, 2013 | 09:12 AM
No$4upgrades's Avatar
Default Airing down???
I've read a ton on here about airing down and was SURPRISED to read that most guys go as low as 12psi. I have stock BFG MT and was a little nervous at 22psi. My concern was a side wall puncture more than loosing a bead. Any thoughts from anyone?
Old Jul 28, 2013 | 09:16 AM
jeepfreakjk's Avatar
This weekend we had guys drop to 10psi 8psi i went to 12 but gotta be careful it's easy to bust s bead that low
Old Jul 28, 2013 | 09:52 AM
RodCyn's Avatar
Since you mentioned yours were stock BFG's, you can generally go down to 15 psi, which is what I ran when I had stockers. It all depends on the size of the tire and weight of the vehicle.
With my 37's, I run them at 9 psi for good traction and have had good luck not blowing a bead. As soon as I acquire some bead locks, I'll run them even lower
Old Jul 28, 2013 | 10:01 AM
jadmt's Avatar
JK-Forum Ambassador
I was nervous too when aired down to 20lbs. I stopped being nervious after seeing nearly the entire weight of the jeep (JKU) supported by one tire when fully flexed and barely bulged. My are Toyo AT2's in eload.
Old Jul 28, 2013 | 10:21 AM
kh202's Avatar
I aired down to 18-20 psi with my stock wrangler sra's and stock wheels. With 35's on 15x8 wheels, I do 10-14 depending on trails
Old Jul 28, 2013 | 10:38 AM
JnT's Avatar
JnT
14PSI on our 35" Duratracs. Any of the guys I'm seen cut a sidewall were running fully aired. I'm on my second set of Dura's and I do a lot of crawling over stumps and sharp sticks without issue. Just go slow and be aware of what your tires are doing/driving over
Old Jul 28, 2013 | 10:39 AM
bthomas's Avatar
I go down to 12-14 lbs. with 285/75-17 KM2's on stock wheels with no problems yet.
Old Jul 28, 2013 | 01:23 PM
revvinkevin's Avatar
I'm a 12 psi kinda guy, no problems so far and the grip is much better. Just take it easy and you'll be fine.
Old Jul 28, 2013 | 01:56 PM
Gkarshens's Avatar
I learned the air down lesson the hard way... Punctured a sidewall because I wasn't aired down. I had always assumed it was mor for traction and figured I would air down when I started slipping. Never occurred to me that punctures were more likely at full pressure. Oh well, I got new wheels and tires out of it! :-)
Old Jul 28, 2013 | 02:03 PM
Da Q's Avatar
34" Mickey Thompson Baja MTZ's...12lbs psi, 40mph all day long on the dirt roads. I run 12lbs often.
