Airing Down Tires
What tools or device does everyone use to air down their tires before hitting the trails? I have looked at a few from 4WD but would like some input on the good/bad on what is being used? Using a tire pressure gauge takes way to long.
https://www.google.com/shopping/prod...ed=0CF0Q8wIwAQ
Just screwem on (tighter for a faster release, loose for a slower release)
I got a valve core removal kit that comes with extra valve cores
I unscrew the valve core and let the air rush out and replace it once it gets to about 18psi... I take it the rest of the way down using the little nippe on the back of my tire pressure guage.
I do the same thing. Fastest way IMO. If you are good and used to doing it, you can drop it to 1 PSI above where you want it, then put the core back in and be right where you want it. Its that easy.
