Alignment?
Loosen the 2 bolts (15mm I believe) on the drag link turnbuckle and rotate until the steering wheel is centered. It's easiest with another person but can be done alone. It may take a couple attempts before it's centered up perfectly.
Just for clarity: Only two things on your Jeep frontend to be aligned, unless you've modified your components: Toe in and steering wheel centering. An alignment shop will likely still charge you $80, or so, and both are easily performed by you (with a helper) in your driveway.
What was you doing to get your steering wheel out of whack , I ask because the issues you said could also be to tie rod to much toe in or out will give you the same problems
So, I drove my left front up a 3ft vertical cement wall at work. Because my coworkers said I couldn't lol. So here we are
