Alignment
Old Jun 23, 2016 | 04:57 PM
Croce's Avatar
Originally Posted by Dbmoorejr
Ok so .. Don't have all the numbers but the specks were all green and centered except caster. They were both 3.1. It is flighty and it has all been tightened to spec. Nothing is loose or not to spec. Grade 8 kit done. I didn't actually get the alignment because he said if I wanted to fix caster and bring it back he would only charge me for one visit. I did see the machine and it might have needed a bit of toe in on the left side. But every thing else was dead on.
Sent using smoke signals
Was the Jeep on the ground when everything was loosened and re-torqued? A lot of people report flighty steering if the control arms were tightened when the jeep was in the air/on a lift/not on the ground causing tension on the bushings making the jeep feel flighty
Old Jun 23, 2016 | 05:41 PM
zstairlessone's Avatar
^^^ Exactly, if it was done in a shop there is probably a 50% chance they just rattle gunned everything on the lift, no torque wrench needed :o
Old Jun 24, 2016 | 12:16 PM
Dbmoorejr's Avatar
I did it at home on the ground
Dbmoorejr's Avatar
On the ground.
Old Jun 24, 2016 | 04:12 PM
nthinuf's Avatar
The usual target is between 4-5 degrees of caster. Some go a little higher, but you need to watch the driveshaft angles. If you go for brackets, any of the sets with multiple holes (lift heights) should be fine. At a guess, you'll use the middle set (3.5"), but the 2.5" holes would probably work as well.
But again, before running out an buying parts, why is your caster low? The Mopar 3" stage 3 comes with new control arms, I take it they were not included? Or is something else going on and you are adding a second form of caster correction?
Old Jun 24, 2016 | 04:24 PM
Cats&Jeeps's Avatar
I put my Rubi on a rack today to check it out because it drives like crap. Mopar 3 inch stage 3 JKS track bar brackets and drag link flip kit 35/12.5/20 ALL IS GOOD EXCEPT CASTER IS LOWER LIMIT OF 3.1 Is this my issue and what is a good target. Mopar kit eliminates , and or doesn't include cam bolts for lower arms. Possible suggestions for fix other than control arms wanted. Sent using smoke signals
I have a set of used currie upper adjustable control arms for sale... Get you a good price
Old Jun 25, 2016 | 09:15 AM
Have any pictures of the suspension as it sits?
Old Jun 25, 2016 | 08:07 PM
Dbmoorejr's Avatar
Originally Posted by nthinuf
The usual target is between 4-5 degrees of caster. Some go a little higher, but you need to watch the driveshaft angles. If you go for brackets, any of the sets with multiple holes (lift heights) should be fine. At a guess, you'll use the middle set (3.5"), but the 2.5" holes would probably work as well. But again, before running out an buying parts, why is your caster low? The Mopar 3" stage 3 comes with new control arms, I take it they were not included? Or is something else going on and you are adding a second form of caster correction?
they did com with them but that is a big complaint with older lifts prior to 2013. They corrected it later.
Old Jun 26, 2016 | 05:55 PM
Dbmoorejr's Avatar
Old Jun 27, 2016 | 06:07 AM
Dbmoorejr's Avatar
Bump
