Alignment procedure
Old May 18, 2012 | 02:58 PM
burbingus's Avatar
Default Alignment procedure
Hey guys,
I'm going to go get an alignment done, and I was wondering what services they generally perform for the alignment. Here's what I need done:
Centering/aligning front axle (control arms, trackbar)
Centering/aligning rear axle (control arms, trackbar)
Centering steering
Toe/caster/camber if adjustable
Which of those are generally included in the alignment?
Micah
Old May 18, 2012 | 03:11 PM
Croce's Avatar
For an alignment the only thing they can do is adjust the steering wheel and toe in. Everything else will require additional parts
btw you can easily do both yourself- Here a writeup on it
http://project-jk.com/jeep-jk-write-...-end-alignment
Centering/aligning front axle (control arms, trackbar)- Will need an adj trackbar to center axle (if for some reason it is off center)
Centering/aligning rear axle (control arms, trackbar)- Same thing, adj trackbar
Centering steering- Can be easily done by turning drag link
Toe/caster/camber if adjustable- Can also be easily done by turning tie rod end
Caster - Believe that done by adj control arms
Camber- Believe thats done with adj ball joints
Old May 18, 2012 | 03:14 PM
09jaykay's Avatar
Most places are only gonna adjust toe in and out and center the steering wheel
Originally Posted by burbingus
Hey guys,
Centering steering
Micah
burbingus's Avatar
Originally Posted by Croce
I think for an aligment the only thing they can do is adjust the toe in. other than that like your post said, will require control arms, adj balljoints...
Thanks for the reply. I have adjustable control arms/trackbars which is why I'm wondering. I'm thinking my initial settings with the lift installation might have been off a bit, and I was hoping to have it taken care of when I get an alignment done.
Old May 18, 2012 | 03:26 PM
Croce's Avatar
Id check with the shop first and see if they can/are willing to adjust the trackbar,control arms ect as some shops wont. hate to see you pay for an alignment to find out they wont adjust anything
Old May 18, 2012 | 05:01 PM
burbingus's Avatar
Good call. Thanks for the advice!
